11-28-2003, 09:04 AM
Cheese Ninja
!@#% little plastic piece!
Well, something busted. I'm not exactly sure what it's called, but if you look at the rear A-arms of your car, there is the metal part where the wheels slide onto, then the bearings in the arm, then the knuckles, then whatever the thingie the knuckle slides into. Well, the thingie that the knuckle slides into has one of the tabs broken off, so it sucks. If someone could tell me what EXACTLY the piece is called, it'd be much appreciated. I looked at CJ's list and didn't find what I think it would be called. Also, if an upgrade replaces this piece, or if there is a newer, better version (metal maybe?), please let me know.
Thanks in advance (maybe?)
ThisonetimeIwaslostinthewoodsandIsawthisguywhohada steakandIwaslikewhoa.
11-28-2003, 01:46 PM
I'm not a pyro, really.
a half shaft or dogbone or axle. look for the "guess what came in the mail today" thread he broke his and got some new metal ones.
NEVER UNDERESTIMATE THE POWER
11-28-2003, 03:11 PM
Cheese Ninja
Thanks a bunch dude, I wasn't sure if that was what it was, and now I can get some blingin' metal ones I guess.
11-30-2003, 07:39 AM
Cheese Ninja
Crap, I guess the thing I'm not thinking of is the dogbone. Found a picture of a little mod someone did, and even has nice little arrows pointing to the part that broke.
If you can't see it very well, it's like a cup with two notches on opposite sides of one another. The dogbone has the little things that stick out, stubs, if you will, that insert into these, which spin the axle/wheel. I believe he referred to it as the "output shaft."
12-01-2003, 08:08 PM
Not to be rude, but man, how on earth didja break that? Anyway..I have no idea myself. But my ideas would be:
12414249 HOLDER CENTER SHAFT (REAR) $2.49 Not In Stock
12414314 JOINT CUP CENTER SHAFT $2.49 Not In Stock
12414322 JOINT CUP CENTER LEFT $2.49 Not In Stock
Its not the most helpful I know..but maybe it'll help you narrow it down some. Its basically what I had to do.
I wish my Land Rover was a rotary
12-01-2003, 08:55 PM
like my dog??
on the other end of that peice, mine rounded it self out!!  i put silly putty in my diff and it started working, but not as good.
dose anyone know how i can fix it???
--Chris
Aka...aero528
12-02-2003, 08:30 AM
as long as its on the left side im pretty sure thats what youre looking for. if its the right side use the other joint cup center. i would order them both just so if the other side breaks youll have an extra.
12-31-2003, 02:00 PM
Where did you get that info from?
How do you know it's "not in stock"?
01-01-2004, 09:30 AM
TinyRC PRO Modder
I can make some metal parts
Hello i can make all the axels just not the joints . Check my pic's out in "Mr BigShot Must See Upgrade" in the mods forum
