Old 11-28-2003, 09:04 PM
sawhit4 sawhit4 is offline
my design please look at and comment
heres is my design for a 2wd monster truck style tttt. i plan to make the frame using brass but i dont know how to make the U joints to go from the gear that meshes with the motor gear to the worm gear for the back axel. the ones killer made look like exactly what i need but i dont know how to make them. i think that he works on a scale that would be impossible for me to do right. any help would be great. thanks.
Old 11-30-2003, 01:39 PM
Timbo337 Timbo337 is offline
Send a message via AIM to Timbo337
Your design looks great, except that I think most rear axles on TTTTs are rigidly fixed to the frame, they don't articulate. Well, thats how mine works and a lot of others that ive seen. However, if you do plan on making it articulate, use springs to keep the frame and body level. If you mount the rear axle rigid to the frame, you won't need the u joints. It makes it so much simpler for your first truck.After you make your first, then I think you would want to go on to bigger things.
-Tim
mtb=beast
Old 11-30-2003, 02:35 PM
thanks but i think i will make it articulate. if i didnt wouldnt i still need the U joints so i could get the motors power to the axle which would be mounted about an inch below the frame?anyway i found some boat u joints that i think will work.
Old 11-30-2003, 08:06 PM
An inch below the frame? That sounds like a lot in 1/87 scale. But I have a gearbox that attaches to my motor, which I run a shaft from the gearbox to a worm gear that drives the axle gear. I'll get a pic soon, as I am almost done with the construction. Are you looking at the Graupner uj's? Just wondering, I've heard abot people using them, but I haven't seen any in real life.
-Tim
mtb=beast
Old 11-30-2003, 08:18 PM
oh sorry i forgot to post that this car will be about 1/30 something because it will be my first small car to make
Old 12-01-2003, 07:49 PM
Cool, a 1/30 scale truck. I'm going to make one of those soon too. Do you know what the part number for the boat ujoints is?
-Tim
mtb=beast
Old 12-01-2003, 08:22 PM
no i dont but go to www.towerhobbies and look under boats and i think there is a section didicated to u joints. you may also be able to find them by goin to the shop by manufacturer and lookin under traxxas. the joins are for one of the villan boats you should be able to find them at hobbytown usa.have you thought of where you will get gears? i might change my design to a more dune buggy style. i dont know yet
Old 12-01-2003, 11:25 PM
I think the Traxxas ones are too big, but I dont know for sure. Does anyone else know about using these boat joints?
-Tim
mtb=beast
Old 12-02-2003, 07:59 AM
ive heard the graupner joints are good but i havnt seen any. i checked tower hobbies and they dont carry graupner. i think you might have to order from another country.
Old 12-07-2003, 11:22 PM
egdinger egdinger is offline
hobbylobby sells graupner (sp?) stuff check there.
