11-25-2003, 11:03 PM
Fred Obando Rox My Sox
CLEAN IT! i went 2 days of driving it on "clean" wood floors atthe Y raquetball courts, and its real dirty, taking it all apart and spraying it all down with cleaner, accept electrical parts of course
AIM: CoryRSmith37
2000 Honda Civic,
Stage 2 Drag Motor,
Yellow Front, Blue Rear Springs,
LED Lighting Kit,
AWD Kit,
Hard Treaded Tires,
Metal Bearings,
All at a 30% Discount, OORAH!
11-26-2003, 10:59 AM
sleeper mall civic
use a soft tooth brush to go over everything
douglascounty!!!
11-26-2003, 04:16 PM
Originally posted by CtrlAltDel
haha here is one...
1. NEVER DRIVE IT OUTSIDE
I drive mine outside all the time and it just gets a little scraped up thts all
11-28-2003, 02:29 PM
the "too many tires" guy
The Bit Ghar-g run in trick does require the gears in the car.
This is not to burn-in your motor, but to wear in your "clean" gearing so they have less rolling resistance. This gives you a very slight increase in speed, but the more important part is the lower noise level the car runs at. Most of the noise though seems to be from the differential, and the run-in trick does not seem to work well with it. Plus my differntial is kinda screwed right now, one wheel consistantly gets more power than the other, hopefully RS gets replacement parts soon, so I can get a few of these since this last one only lasted about 12 hours.
I also need a:
new passenger mirror, I broke it off in a freak collision with a steel cabinet
another 1.5 tie rod, bent mine a bit beyond repair, same collision
New lugs, just cause I'm too lazy to go to mr. metric to buy some.
New hard treads, cause I wear em out like mad
Kinda shows how hard I run these things......the cabinet incident was where I lost grip and sideswiped the cabinet going full-bore. Since then, my car veers to the right constantly, and changing the tie rod fixed it, but now I run more camber than I like...oh well can't have it all when your broke
Xmod White Supra RWD
Body Kit
Stage 2 drag motor
ball bearings, 1.5 tie rod
Hard tread Tires
NiMH batteries
Grease packed rear ball diff.
Yellow Skyline RWD
Stage 2 Drag motor
Yellow springs all around
4.5 Tie Rod
Soft Tread Tires
11-28-2003, 06:01 PM
I make great sandwiches
I use cotton swabs and baby wipes... because the swabs can reach where my fingers cannot reach. (if you are in a rush) but I use the baby wipes when I am finished for the day. I always race my friend outside. works for me
My Xmod:
11-28-2003, 06:07 PM
like my dog??
hey mustange steve, i just ordered two new diffs from rs, so they do have replacment parts. they will be here in 5-10 days!  my diff is totaly messed up!! it does not transfer ANY power to the wheels. the inside where the saft goes in is striped.
--Chris
Aka...aero528
11-30-2003, 03:25 AM
sleeper mall civic
never let ur bat wire touch ur antena wire (exsposed ends) or u will fry it like mine
douglascounty!!!
12-07-2003, 02:16 AM
sleeper mall civic
when ur taking ur wheels of always make sure u get the bearing or bushings back in when u clean out around them cause if one isnt in there right it slows down big time
douglascounty!!!
12-07-2003, 12:11 PM
RC Tinkerer
Wiping down the body, rims, tires, and any other flat smooth surface with a dryer sheet will reduce the ammount of dust and dirt that sticks to your car. (Anti static)
If you run on carpet, vacumb just before you play, that will help reduce the ammount of dust and dirt in the carpet, and also help reduce what sticks to your car.
Use a tiny brush like you would find in a beard trimmer, or in the Zip Zaps tool kit, to clean the hard to reach places. Q-Tips work OK, but they could snag and leave fibers in the berrings.
When you clean your car body, use a mild all surface cleaner and a soft cloth. Do not use paper towel or tissues. Paper products are course and will scratch your body, especially if you have a custom paint job.
Use Extra Fine Powder Graphite on your axels, or any parts you want to lube up. If you use anything that is liquid based it will attract dirt and dust.
12-24-2003, 01:55 PM
sleeper mall civic
when ur driving out side take ur kit off and put on the stock kit and take the mirrors off so u dont scratch or break anything
u should c my stock kit
douglascounty!!!
