Old 11-24-2003, 07:00 PM
SuPeRdUdE SuPeRdUdE is offline
Question questions reguarding homemades
instead of buying a chassis i want to make a homemade one but i have some questions: 1.what material do you make the chassis out of 2.how would you make the steering 3.what is the most simple drivetrain to handmake 4.how would you assemble the chassis? and i am not making it 4wd because i want it as simple as it can get oh! i almost forgot to ask, what would be the best truck to start with for a first tttt
If i was atacked by a rancid 5 legged monkey, i would put him in the fridge until he clamed down. Then i would ask him what happens to the light when you shut the door.
Old 11-24-2003, 09:08 PM
Comrade_Boris's Avatar
Confirmed: Lost In Fog
the best first truck is a Man 5 Ton
-Andres
Old 11-25-2003, 07:57 AM
Thorsten Thorsten is offline
Hi,
here (http://www.microtrucks.de/tttt/Bastel/bastel.html) you find a little "howto" about a simple TTTT. OK, its in german, but I think babelfish or google will be able to help you to solve this problem ;-)
There also some good pictures of the frame and the drivetrain.
The best choice to start is a 2 axle Truck with a lot of space inside.
The brass frame is a nice thing, but it isnt nessesary. You can also use the original frame from the resign modell.
Another good way to starting a rc-truck scaled 1:87 is reasemble a Fallercar (http://www.faller.de/html/carsyst1engl.html).
Here you only have to build in the electronic parts. Steering axle and Driveline are already inside.
Best regards
Thorsten
www.mikromodell.de
Old 11-25-2003, 11:33 AM
Question chassis
wait, so you can use the original chassis that comes with the model kit?
Old 11-26-2003, 02:31 AM
Hi,
yes you can use the original resign-frame. In some cases it is bette to glue some extra resin-stripes on it to make it stronger.
The brass frame is a "nice to have", but ist isnt nessesary in every case.
This truck on the picture is builded without a brass-frame
best regards
Thorsten
www.mikromodell.de
Old 11-26-2003, 02:33 AM
Dachser Spedition Truck without a brass frame
Old 11-26-2003, 04:21 PM
Question suspension?
can you use suspension on the original chassis?
Old 11-27-2003, 03:58 AM
Hi,
the car on the picture is a modified "Fallercar".
But you can use a Faller frontaxle (sale by the Fallercar dealer as a spare part) in nearly every other car. So you have a good working moving frontaxle.
It can be mounted by using normal resign glue.
To suspend the rearaxle you have to glue the garbbox in the Mainframe. I mostly use the 1:30 or 1:120 gearboxes from www.mikroantriebe.de
This one you can mounted by using rapid glue or resin glue.
If you want a supension with springs, so I suggesst you to use a brass frame.
best regards
Thorsten
www.mikromodell.de
Old 11-27-2003, 09:53 AM
too bad i cant buy a faller truck near me
Old 11-27-2003, 10:14 AM
Hi,
what is your location????
Do you know "onlineshopping" ;-)
best regards
Thorsten
Old 11-27-2003, 11:56 AM
i live in parkersburg, wv. and they dont sell online
Old 11-27-2003, 01:40 PM
i have seen the Faller car system online at some model strain sites....
i dont remember wich ones in particular but try www.ermodels.com and www.eurorailhobbies.com
-Andres
Old 11-27-2003, 01:50 PM
ahh, found it....they have the car system things here and on the next few pages...: http://www.ermodels.com/productsbyma...72VE&NBReset=3
-Andres
SE Steering Questions Azimov ZipZaps SE 49 02-04-2004 12:11 AM
questions questions questions kasper01001 XMODS 12 01-02-2004 05:38 PM
Bit-Dub Conversion questions mcojoc Bit Char-G / MicroSizers 0 09-25-2003 12:49 PM
Questions for Ahh5hit 55_BrOoKs_55 ZipZaps 8 08-25-2003 08:27 PM
Mini-x tech questions Bravin Neff Mini-X 27 12-28-2002 04:25 PM
