Old 11-23-2003, 01:38 AM
stl2ner stl2ner is offline
has any one tried the spin brush motor mod?
Just wondering if anyone here has tried it, I saw it on another board, I have two of these motors sitting around and was thinking about giving it a try.
Old 11-23-2003, 01:46 AM
dEmOnRaCeR's Avatar
dEmOnRaCeR dEmOnRaCeR is offline
"Its OK I had subway"
I have no clue wut this mod is can u explain or give a link.
Old 11-23-2003, 02:07 AM
http://www.xmodworld.com/modules.php...viewtopic&t=93
Old 11-23-2003, 03:00 AM
rallger's Avatar
rallger rallger is offline
switcher
Send a message via AIM to rallger
looks nice
waht kind of stuff would u need in relation to pinion pullers/pinions etc
Old 11-23-2003, 08:45 PM
sokalxballa's Avatar
sokalxballa sokalxballa is offline
Xmod Modifier
Send a message via AIM to sokalxballa Send a message via Yahoo to sokalxballa
hmmmmz, I got a billion motors laying around I took out of old broken toys.... I'm going to need a testmod. Does the gear on the spin brush fit right into the xmods gear or do I need to swap?
XMOD 1997 Red Toyota Supra //LED kit//Skyline Rims//
Blown White Stock Stage 1 motor (RIP)
Modified SBP High Torque Drift Motor
8 tooth pinion (lightened)
Nasty sleeper paint job
5th cell N-cell (rare) mod!!!
Pioneer in SBP 5th n-cell Technology.
4 IC3's 800mah Batteries & 1 n-cell (RS)
Silver RSX (Scraped Skyline and RSX)
Made from returned broken cars.
RSX and Supra Rims
All stock skyline chasis shortened to fit RSX.
Uses an RSX shaft and Broken limited slip gear.
White 6 cell Supra SBP II Hybred With unknown magnets... Bearings and oil cooled. Too fast! Eats tires
Old 11-23-2003, 09:48 PM
you need to either buy a pinion or pull a pinion from an xmod motor.
Old 11-23-2003, 11:13 PM
xmodsupra xmodsupra is offline
I just got my supra today, in fact i just got it together an hour ago, i am going to pick up the 5th cell for the "super charger" and the brush tomorrow, sounds AWSOME.
Project Supra:
97 Supra
Black, Red hood
Mountain Dew skid plate
Custom Spinbrush Motor (11T/blue gear)
Custom 5th Cell System (9V)
Stock tires, superglued (didnt help)
Light kit
Wild body kit
more soon
jaubery jaubery is offline
I tried the ff-180 or spin brush motor. The mod requires you to shim the rear motor mounts. You can't use the front mount at all. The motor also requires capacitors to be soldered onto it.
As far as performance goes I had dissapointing results. It has good acceleration, but the motor has no top end. A stage 2 drag is faster.
jaubery
Old 11-24-2003, 12:06 AM
thats why u need to change the gear to 9 or 11
Project Supra:
97 Supra
Black, Red hood
Light kit
Wild body kit
more soon
Old 11-24-2003, 01:17 AM
I have yet to insall the motor, cause I don't have a pinion puller, but the motors I have fit perfectly without any mods other than soldering on the connections and adding the correct pinion gear. are you sure you have the right motor?
Old 11-24-2003, 08:07 AM
picking up paint, the SB motor, and the fifth cell tonight, o yes......
Project Supra:
97 Supra
Black, Red hood
Light kit
Wild body kit
more soon
Old 11-24-2003, 09:57 AM
xmodssupra,
I tried a 13 tooth pinion gear. The top speed was still no better than a stage 2 drag motor.
Old 11-24-2003, 10:02 AM
stl2ner,
I have the right motor. The model number is ff-180sh-22100. It does not fit with the front mount on. Try putting the motor in without the pinion gear on for a test fit. You don't need a pinion puller to do the mod. Buy a mini-z pinion and grind it down a little.
Old 11-24-2003, 12:22 PM
major skyline's Avatar
major skyline major skyline is offline
Sleeper Supra
i did it, i used a Crest Spin-brush Pro. the motor fit perfectly. also u dont need a pinion puller, just use a propane torch to heat up the pinion. the brass will expand faster than the steel. then just use a pair of pliars to pull it off. i took the caps, pinion, and gear off of the blue stage 2. for the soldering just put alot of flux on the can an it works just fine. i used blue gear and the results were awesome just as much torque as the white stage 2 and just as topend as the yellow. very happy with it.
Old 11-24-2003, 01:40 PM
Xmod Modifier
As an extended experiment I wet out and bought Three different types of spinbrushes. I'm taking one for the team. I got the reach, The cologate and the Crest pro. I got the first to at Big lot for 3&4 dollars. I am opening them up in a minute, I'm going to take pics and make reports during the week as I test the size (will it fit?) and some other data.
RSX and Supra Rims
Spin Brush Motor NSXJCG XMODS Parts and Hop-Ups 0 01-26-2006 05:15 PM
crest spin brush motor dmk101 XMODS Parts and Hop-Ups 6 06-29-2004 07:44 PM
spin brush plus flashing lights richh XMODS Mods and Projects 0 12-06-2003 12:50 PM
Crest Spin Brush motor mod RSXRacer001 XMODS 3 12-01-2003 07:47 PM
Are the rear wheels suppose to spin freely? Racer240 XMODS 1 11-20-2003 09:31 AM
