11-22-2003, 03:32 PM
how many volts can it handle
I have got 2 12v camera batteries that have the same diameter of the AAA battery and I have got the materials to put in spacers to fill the gap for the remainding 2 battery spaces, will it fry my board or will the spacers remove enough voltage to run it at a safe voltage.
so many mods, so little time
11-22-2003, 05:54 PM
got boost?
hi
welcome to the forums
please use search there is a lot of threads about this
All Wheel Drive=Fun!!!
11-22-2003, 11:34 PM
yeah it will fry it you moron. 8.4 volts max!!!!!
BC EDIT: Please do not insult other members.
\| |_ |\ |\
11-23-2003, 09:08 AM
MY ENZO!!!!!!
wasnt there 1 guy who did 18 volts and it worked
11-23-2003, 05:28 PM
Sleeper Supra
No, he used 1 rechargable 9v(8.2v) and removed the aaa's on both sides
11-23-2003, 08:57 PM
I'm running 4 AAA's and one 9V and its working, but seems to be at its limit. The thing is extremely fast though!
12-30-2003, 04:32 PM
where can i get small 12v batteries?
12-30-2003, 06:14 PM
RadioShack is pretty confident in their battery selection, but I didn't find anything that size on the website. Try Circuit City or HobbyTown USA.
Mazda Savanna RX-7
stage 2 motor | spaced wheels
01-01-2004, 03:31 PM
BestBuy has a 12volt the size of a tootsie roll for only $2.99! I think I'm gonna try running this all alone. This way I'll free up tons of space inside the car for all kinds of neat stuff!
01-01-2004, 03:38 PM
xmod destroyer
who told you taht 8.4 would fry it
350z-SS 130 motor, bearings cf driveshaft, custom paint,
supra- high torque 180, 6 cell bearings,
civic- powerdash, bearings,cf driveshaft
rsx-fried
4supras fried
2 skylines detroyed
1 civic destroyee
01-02-2004, 10:03 AM
BC EDIT: I removed all of your comments. The whole thing was way out of line. This is the second time I have edited your post due to innapropriate language. No more warnings, you next will result in being BANNED.
01-02-2004, 10:48 AM
Ya know, using a Zener diode could keep the rest of the electronics at a happy 4.8V, while allowing more power to the (upgraded, of course) FETs and motor. I think I'm going to give it a try.
01-02-2004, 02:06 PM
i didnt use bad language... everything i said was marked by *'s.
if that is not allowed, please discard all swear filters, and do not allow any recreation of any swear word.. such as 5hit. see thats worse than *hit. also SHlT isnt a swear word as it is clearly SHLT.
01-02-2004, 02:14 PM
It was not only the words you used, but the way you used them and the insults. I will not discuss this any further, and I suggest the same for you. PERIOD.
01-02-2004, 04:00 PM
sLoWly gOInG iNsAnE
Re: how many volts can it handle
A 12v camera battery is probablly going to be a Lithium battery. This type of battery is not good to use for a high current drain application such as the Xmods. The lithium batteries have a very high internal resistance. When too much current draw is demanded they simply add a large amount of resistance in the supply circuitry. In short - you don't get the performance gains you would expect.
It is best to try and use NiMH cells instead. Take a look at this thread to see if you would want to try this for voltage increase - http://www.tinyrc.com/forums/showthr...threadid=16985 -
These batteries have the same current drain as all of the rechargeable AAAs everyone is currently using.
