Old 11-15-2003, 08:26 PM
catman25 catman25 is offline
Car was fine now stuttering how to fix
I'm pissed returned one xmod cause it happened before.Now my replacement like 2 weeks later has the same stuttering problem.If its like 10 inches away fine. but like 3 feet or more it breaks up and gets a signal then looses it.like a car running outa gas...what can i check,what couyld be wrong? thanks all!...
... p.s. it must be a tx or rx problem right ?
Old 11-15-2003, 08:35 PM
viperkilla's Avatar
Hmm...Id make sure the antennea on the chassis was on correcty. Also make sure it is screwed in tight.
Old 11-15-2003, 11:47 PM
JesterDotcom JesterDotcom is offline
3D Racer
my car was screwing up cause i put grease on the gears and then the grease collected dirt and stuff and my car would stop and start and stop and start over and over when i finally figured out what was going on it took me forever to clean all the gears so yah don't do that
Old 11-16-2003, 12:12 AM
johnfish johnfish is offline
Have you tried replacing the transmitter battery (9V one)? It sounds alot like the transmitter range has dropped.
John
Old 11-16-2003, 05:33 AM
i replaced that quit a few times and no diferance...Any one else has this problem ?
Old 11-16-2003, 03:01 PM
aperson's Avatar
aperson aperson is offline
i have this problem too. its on my Supra that i got last night. after my 5 skylines i decided i needed a supra but now this thing does it too. guess this'll be my inside car. its winter and it wont run outside. so it'll work for now. you could also try searching.
Old 11-16-2003, 03:20 PM
adroit adroit is offline
Try removing your crystal from the car body and then putting it back in, making sure it is snug. If this does not help you may have fried your receiver by touching the battery contacts the the heat sync. Good luck.
Old 11-16-2003, 03:32 PM
skklown skklown is offline
my stuttering on my car is opposite of urs. when i am 2 feet from the car it stutters, but if i step away it goes fine. y is this happening?
xmod blue civic ricemobile.
Old 11-17-2003, 01:40 AM
vtheo's Avatar
vtheo vtheo is offline
Monoaural.
also try shimming the 9v in the controller with some folded up paper.. some 9vs are shorter than others...
J-On
Old 11-17-2003, 01:42 PM
Se7en Se7en is offline
maybe you are getting interferance from something? try a different crystal set if you can. or if indoors, shut off tv's, lamps with dimmer switches, or any wall mount dimmer switches.
Old 11-17-2003, 02:34 PM
viperkilla's Avatar
Yea I'd have to agree with Se7en. I think that you are getting some interference. That happened to my zip zaps.
Car wont go backwards... Drag00n Bit Char-G / MicroSizers 3 11-15-2003 12:56 AM
How To Fix The Stuttering problem ketis88 XMODS 0 10-24-2003 08:17 AM
mutant car fireball16789 Bit Char-G Mods and Projects 2 10-16-2003 09:08 PM
what is a pcb, and how to i fix it so that i can put a 3.8 MOTOR in my car? jutte07 ZipZaps 6 12-30-2002 11:49 PM
what is a pcb, and how to i fix it so that i can put a 3.8 MOTOR in my car? jutte07 ZipZaps 2 12-28-2002 02:13 AM
