Old 11-13-2003, 06:08 PM
YeLLoW GT-R R34 YeLLoW GT-R R34 is offline
Send a message via AIM to YeLLoW GT-R R34
Opps my bad BC........I meant Cmuench
Old 11-13-2003, 09:44 PM
Bad Company's Avatar
FYI:
You can use the battery holder from the chassis, and it will fit on top of the chassis and you can put the Civic body on without any modification to the body or chassis. If you don't have a spare chassis to rob the battery holder from, you can order a replacement one from RS.
Old 11-13-2003, 10:01 PM
Got 4.2 King? I do : )
is there any chance it will fit under a skyline with little no modification?
MY XMOD!
Yellow skyline
Springs: Hard all around
1.5 degree toe in
hard slicks
Top Speed stage 2 motor
full bearings
AWD
6 spoke wheel upgrade
energizer rechargeables
6 Cell Upgrade
Old 11-13-2003, 10:12 PM
Yep, just tried it. Slapped the body on and snapped the tab lock without any problems. No bushings needed or no need to shave anything on the body.
Old 11-13-2003, 10:16 PM
Here is a pic of where I mount it. This is without a heat sink on the motor, but there is a gap between the motor and the bottom of the battery holder the sam as the height of the heat sink.
Old 11-13-2003, 10:17 PM
Viper966 Viper966 is offline
Send a message via AIM to Viper966
part # for replacement battery holder?
Old 11-13-2003, 10:20 PM
Left Side: 12414298
Right Side: 12414306
Check CJ's FAQ for more numbers...
EDIT: I forgot, you do have to remove two little tabs on the bottom of the battery holder, but no biggie at all.
Old 11-14-2003, 08:11 AM
cmuench cmuench is offline
Supra king
Send a message via AIM to cmuench
6 cell
Hey Bad Company,
I got a bit of a problem. When i install my 6 cell mod it flies. When ever I install my 6 cell mod and logic lights it fries the antenna internals and the range gets shot. Im on my 3rd car now cause I can never find why this is occuring. Just to make sure i was not shorting out everything, I replaced my quick disconnect with the quick disconnect that is used on the motor. I also tested the final output with a voltameter and evreything is in range. I got a new car but i am hesitent on weather I should re-install it or not. Please help me BC
**1997 Supra Xmod**
-Stage 10 Motor w/11 tooth
-AWD
-Wild body w/ Custom paint
-6 AAA battery mod (7.2v)
-Double head/tail light mod (Not used with 6 cell)
-Hard suspension w/ 4.5 toe-in
-upgraded wheels with hard tires
-Metal bearings upgrade
Old 11-14-2003, 11:51 AM
4G63T's Avatar
4G63T 4G63T is offline
got boost?
well if it happened on 2 cars already don't install the lights
my 02. cents
All Wheel Drive=Fun!!!
Old 11-14-2003, 12:40 PM
Supra king
The thing is that other have gotten it to work fine with the upped current and lights. I just want to find out how this was done
**1997 Supra Xmod**
-AWD
Old 11-14-2003, 02:48 PM
4G63T's Avatar
got boost?
o ok i see well good luck
Old 11-14-2003, 04:12 PM
I haven't tried to hook up the lights on mine, after hearing about this problem. I would say just leave them off untill we can figure out what is wrong. I'm not much of an electronics whiz, so I may not be too much help, but I'm sure someone here will get to the bottom of it.
If we could only get a wiring diagram?
Old 11-15-2003, 12:45 PM
Jamezracer Jamezracer is offline
Question
For what it's worth, I gave a pair of lithium polymer cells a shot last night and all I can say is WOW!
Hey FESCSteve
where did you find your lithium polymer cells, I've been looking for weeks to get some.
Old 11-15-2003, 04:49 PM
FESCSteve FESCSteve is offline
Jamez,
The cells I used are both 1200mah E-Tech and a 230mah cell I am testing out that is not on teh market yet.
The 1200's are just barely too large to fit under the RSX body in place of the stock AAA cell holders. However the 230 cells fit in the top of the body with room to spare.
I also have some 340 Kokam SHC cells which are a bit larger than the 230 cells but will fit on the sides of the chassis.
Get the 340s at:
http://www.b-p-p.com
2 in series will make this car cook. just be aware that you should run a stage 1 motor with a heatsink if you are goign to run it all out for more than a couple of minutes. THe stage 2 motor gets pretty warm at this voltage and I doubt it puts out any more power to the wheels due to effeciency losses.
Also know that the cells will be ruined if they are discharged much below 3V per cell (6v for a pair in series) so you ar eon your own there. They also take a specialized charger to charge and take an hour or more to charge.
Just some of the drawbacks, but they simply can't be beat comapred to lithium-metal, nimh or nicad cells.
Old 11-15-2003, 06:55 PM
Talking
thanks a ton, great site, I'll be sure to get some soon.
Tri cell mod. RobotGT Tips, Mods and Reviews 1 02-24-2010 05:27 AM
Tri cell mod RobotGT Bit Char-G Mods and Projects 5 09-25-2003 05:22 PM
Tri cell mod RobotGT Bit Char-G / MicroSizers 3 07-27-2003 12:06 PM
Dual cell mod ( will 2 - 50 mah's achieve + speed?) Suntzu28 ZipZaps 7 01-11-2003 10:57 AM
