Old 11-11-2003, 05:23 PM
Pinoy274
range problems after 6-cell mod??
hey there...
is anyone else experiencing problems with control range after doing the 6-cell mod? a friend of mine and i are experiencing the same thing, after 10 feet, we lost control... lights go off and the car won't respond until we get any closer...
anyone with a solution??
all help will be greatly appreciated
pinoy274
Old 11-11-2003, 05:27 PM
Bad Company's Avatar
I haven't noticed any problems yet, I still get around 80 feet before it starts wigging out.
Maybe, the antenna wire accidently touched one of the batteries?
Old 11-11-2003, 08:52 PM
Pinoy274
i'll look into it...
nah.. can't be that, cause when i moved my antenna to the front, i shortened it to the necessary length plus a lil slack for ease of removal
thanks tho
Old 11-11-2003, 09:07 PM
dEmOnRaCeR's Avatar
dEmOnRaCeR dEmOnRaCeR is offline
"Its OK I had subway"
wut bout your crystal
Old 11-12-2003, 02:26 AM
YeLLoW GT-R R34 YeLLoW GT-R R34 is offline
Send a message via AIM to YeLLoW GT-R R34
Hmmm.........try using fresh batteries in your controller and car. Like demonracer said, check if those contact things in the crystal are bent and readjust them.
Old 11-17-2003, 02:35 PM
cmuench cmuench is offline
Supra king
Send a message via AIM to cmuench
6 cell range
I had the same problem. The question is were you running a light kit w/ the 6 cell setup.?So far I gone threw 2 cars (RIP) by using the 6 cell system and lights. seems to fry the internals and a nice puff of smoke to boot. Let me know cause BC and I were trying to figure this out on the 7.2 6 cell mod thread.
**1997 Supra Xmod**
-Stage 10 Motor w/11 tooth
-AWD
-Wild body w/ Custom paint
-6 AAA battery mod (7.2v)
-Double head/tail light mod (Not used with 6 cell)
-Hard suspension w/ 4.5 toe-in
-upgraded wheels with hard tires
-Metal bearings upgrade
Old 11-17-2003, 10:32 PM
Pinoy274
yeah, i have lights, but i fixed the problem...
sup cmuench
yeah i have 6 cells with 6 running headlights and 5 running taillights (working third brake light) but i found out that i'd melted the antenna wire over some of the parts of the circuit board where the crystal sits. i did this actually by experimenting with the light kit... wanna see something BRIGHT? turn on your car and control and touch the antenna to an open connection on your connected light kit... (if you have one)... this however heats up your antenna, and causes the insulation around the wire to melt. but it's really cool looking...
anyway, after doing some surgery and soldering another receiver board in, my xmod works fine with lights and 6 cells...
Old 11-17-2003, 10:58 PM
dEmOnRaCeR's Avatar
hey cmuench do u still have the cars that broke would u be willing to give me a part or sumthin drop me an email Knightrider364@hotmail.com
Old 11-18-2003, 07:02 AM
Supra king
Nice Pinoy, What receiver board did you use in order to get this to work correctly. Now that I know for a fact that it is frying with the 6 cell and stock light config, i will just re-connect my 6 cells again tonight and run it. Now lets just hope my stage 10 doesnt go beserk. dEmOnRaCeR I returned the two cars already, Radio shack is getting tired of seeing me every week.
**1997 Supra Xmod**
-AWD
Old 11-18-2003, 01:32 PM
Pinoy274
i had another chassis
i took the board from that one and soldered in the old wires...
by the way... i'm in need of a stock RSX body... anyone got one they could spare? we'll talk about money later... just lemme know if you have one
btw... all those replacement parts CJ listed by RSU number aren't going to be available until Dec. 30.. i called 800-THESHACK...
Dual Cell mod problems Zephyranthes Bit Char-G Mods and Projects 17 02-03-2003 03:30 PM
