Old 11-07-2003, 11:54 PM
Bad Company's Avatar
Here it is with everything installed.
Here is how I did it...
http://www.tinyrc.com/forums/showthr...threadid=14792
Old 11-08-2003, 12:43 AM
Morphes Morphes is offline
well my 2 cents for adding a body would be to hook up sum of those hearing aid batteries (size and weight) to the top and then make a jumper so u dont have to use them all the time, due to not being rechargeable and all.... or u could get sum more of those zip zap batteries (since u kno how much volts it can take now so try differnt types of batteries to see if you can get size down with a rechargeable battery... thats what i would do if i had a job to pay for this if i broke it, LOL
Old 11-08-2003, 05:20 PM
10_second_supra 10_second_supra is offline
xmod destroyer
how did you get that clip thing like that also could you make a step by step tutorial
Old 11-08-2003, 05:28 PM
The clip came from the motor and chassis clip from another chassis which is being used for parts. You can use sta-cons too, which are sorta like quick connects you can get at RS. I will do a tutorial when I do one for the AWD car.
Old 11-09-2003, 04:41 AM
CommanderMcBrid CommanderMcBrid is offline
My question is, when is someone gonna try a pair of 9v batteries?
Aww, yeah, 18v of power...
*car goes really fast for about 1 sec, than explodes in a hiuge fireball*
Umm, it's actually CommanderMcBride. I didn't notice that it didn't fit......
Old 11-09-2003, 09:37 AM
FESCSteve FESCSteve is offline
For what it's worth, I gave a pair of lithium polymer cells a shot last night and all I can say is WOW! 8.4V fresh off a charge, 7.2 nominal and lighter than 4 AAA cells. THe stock electronics seemed to take it in stride although I can't be too sure that I am loosing some power due to overloading the thing (= heat).
I removed the stock battery holders and used double sided foam tape to hold one on each side of the chassis. The body fits too.
I should warn you though that if you discharge these batteries below 3V per cell they will be ruined. So I have to work on a cutoff circuit.
These things are cool, but don't tell the owner (my son) I said so.
Old 11-11-2003, 09:58 AM
cmuench cmuench is offline
Supra king
Send a message via AIM to cmuench
6 AAA mod
I got mine to fit like a champ in my supra body. I am going to take some pics and start a thread when I get home tonight
**1997 Supra Xmod**
-Stage 10 Motor w/11 tooth
-AWD
-Wild body w/ Custom paint
-6 AAA battery mod (7.2v)
-Double head/tail light mod (Not used with 6 cell)
-Hard suspension w/ 4.5 toe-in
-upgraded wheels with hard tires
-Metal bearings upgrade
Old 11-11-2003, 03:14 PM
Supra king
Quick dis-connect
I did mine kind of cheap. I had a old motherboard with fan. I pulled the fan header off the board and cut the wire off the fan. Whala.. a quick disconnect. If you dont have spare parts lying around I would check Radio shack or a hardware store. They would definetly have something to make one
**1997 Supra Xmod**
-AWD
Old 11-11-2003, 03:22 PM
My quick connect came from a spare chassis and a stock motor, but you should be able to find something else if you look at any electronics store.
Old 11-12-2003, 03:25 AM
Hudson5150 Hudson5150 is offline
Send a message via Yahoo to Hudson5150
I used this plug. It works great.
http://www.wsdeans.com/products/plugs/micro_plug.html
Xmod Skyline
X Speed Mini Z Motor
9 tooth Drag gears
6 cell mod
AWD
Blue (stiff) Rear Suspention
Red (soft) Front Suspention
Hard Slicks all around
RS Bearing Set
Old 11-12-2003, 11:05 AM
Supra king
Heres my little setup
I spaced my batteries out a little more
**1997 Supra Xmod**
-AWD
Old 11-12-2003, 07:16 PM
YeLLoW GT-R R34 YeLLoW GT-R R34 is offline
Send a message via AIM to YeLLoW GT-R R34
Hey BC......How are you liking the Stage 10 Motor?
Old 11-12-2003, 07:56 PM
I don't have one yet...and at the price he is asking, I might not get one. This thing goes fast enough for me......for now. Besides, I need to save my money for Emaxx hop ups.....now those are expensive!
Old 11-12-2003, 07:59 PM
dEmOnRaCeR's Avatar
dEmOnRaCeR dEmOnRaCeR is offline
"Its OK I had subway"
hey bc do u have a micro rs4 do u or anybody recommend themand a place to buy them.
Old 11-12-2003, 10:37 PM
Viper966 Viper966 is offline
Send a message via AIM to Viper966
Originally posted by Jakillo
So is the supra the best body to use in order to fit 6 cells? And also can I Sodder the wires together?
i fit 6 under my gtr
