Old 11-10-2003, 08:48 PM
NOS man's Avatar
NOS man NOS man is offline
SHYMERLOO!!!!
Send a message via AIM to NOS man
i gotta problem help me out please...
i gotta white supra runnin everything in my signature. it goes really slow on full batteries. does anyone know whats wrong wit it? if not, can i get a number to call besides 1800 the shack or my local radioshack? does anyone have superstreets number?
What IM rUnnin
white toyota supra with:
All Wheel Drive
ball bearing upgrade
light set
stage 2 motor upgrade(blue)
nimh cell upgrade.
ENS (electric NOS simulation)
smoke exaust
fire exaust(optional)
!!!!!!!!SCREAMS!!!!!!!
Old 11-10-2003, 11:16 PM
Hudson5150 Hudson5150 is offline
Send a message via Yahoo to Hudson5150
Try checking the voltage of the batteries and see if they are getting a full charge. It may be your charger and not the car. Also make sure all the gears are clean of any debris. The drive shaft can get dirty be sure to check it too. If this all checks out try using different motors, could be your motor is burned out.
Xmod Skyline
X Speed Mini Z Motor
9 tooth Drag gears
6 cell mod
AWD
Blue (stiff) Rear Suspention
Red (soft) Front Suspention
Hard Slicks all around
RS Bearing Set
Old 11-11-2003, 10:04 AM
Trickbike Trickbike is offline
What do you think SuperStreet is going to do for you?
Old 11-11-2003, 10:20 AM
Easymoney Easymoney is offline
Howdy,
You might want to check and make sure you don't have your wheels tightened down to tight. It can cause the bearings to bind and cause a whole lot of friction. Well hope this helps. Later
Easymoney
1999 Red & Silver Nissan Skyline R34:
AWD, All RS Hop Ups, Tiny R/C Bearings, GPM rear outdrives and axle shafts
1999 Black Nissan Skyline R34:
AWD, All RS Hop Ups, Tiny RC bearings
1965 Blue Ford Mustang:
RWD, All RS Hop Ups
2004 Blue Subaru Impreza WRX STi:
AWD, All RS Hop Ups
2005 Blue Ford F-150:
Lifted 4x4, All RS Hop Ups
Old 11-11-2003, 10:36 AM
Also check the the gears are meshing together properly.
Old 11-11-2003, 02:07 PM
viperkilla's Avatar
You should check the gears. This happened to me, and my car didnt run. So I noticed the gears werent meshing propertly. So then I just fixed it and it works well.
Steering problem rody XMODS 1 01-29-2007 10:18 AM
sputtering problem with my new zap... Cool Dad ZipZaps 12 06-20-2003 11:05 PM
Dogbones popping out? No problem. bluemax_1 Mini-X 3 04-01-2003 10:39 PM
Transmitter problem (picture included) ryanhook Bit Char-G / MicroSizers 11 12-26-2002 08:29 PM
AH-HA!!! Solved uneven steering problem! mechanist ZipZaps 8 10-17-2002 09:24 PM
