Go Back   TinyRC.com > 1/24 and Smaller > Mini-X > Mini-X Gallery
Old 11-04-2003, 02:16 PM
diets diets is offline
Baja Bug
Hi!
My first Mini-X Mod and what i have done so far:
Mounting the very popular Tamiya wheels.
Raised the Mini-X by cutting the suspension stops.
Changed the motor to a Topcad R2 Modified.
Modified the gearbox to increase the gear ratio.
Ground clearance is about 17 mm.
Most of the modifications were described and discussed in this forum. So I have to thank you all.
diets - more mod's are waiting
Old 11-04-2003, 02:29 PM
3series takumi's Avatar
mini-eX-Driver
pleaz show some pix of the chassis!
soon to be
mini cooperS (bmw) mini-x
novak xxl receiver
lrp quantum micro esc
hpi micro mod
5 2/3a zapped cells
novak 10v 4700u power cap
xmod suspension
xmod wheels and tire upgrade
Old 11-04-2003, 02:45 PM
Here are some more pic's.
steering
topview
sideview
diets - mini-x is maxi-fun
Old 11-04-2003, 10:11 PM
Alexman Alexman is offline
Send a message via AIM to Alexman
can you tell us/me in detail what you did and what you bought please?
I'm new to this stuff,
-Alexman
Old 11-05-2003, 12:24 AM
helldriver's Avatar
helldriver helldriver is offline
Send a message via Yahoo to helldriver
pinion/spurs gear?
Originally posted by diets
steering
At pic #02, what is the combination of pinion and spurs gears do you use? I'm interested to that spurs gear.
Good job. man!
Old 11-05-2003, 06:44 AM
Cian's Avatar
Cian Cian is offline
Got Cheese?
omigod that is FANTASTIC!!
I really love wht you did there, It's the most innovative X I've seen since takumi's!!!
Nice paint job too!
Lisa: And vice versa...
Old 11-05-2003, 06:16 PM
@helldriver
I made the same experience as you did. I burnt my stock motor within 5 minutes driving with the monster wheels.
I am using 6 cells and a GM SX3R esc, which has no limit with 130 and 180 motors. So I decided to use a Topcad R2 Modified motor. I use this motor in the overland as well, and i think it is one of the best 130 you can get - comparing price and value. It is fast and has a lot of torque.
Going 4 wd with a standard 130 motor means modifying the gear box and changing the motor mount - but "how to".
I had the same idea as you, using a main power shaft with a pinion and spur gear combination. My pinion gears are from the overland or hpi micro. I have them from 9T to 13T. The spur gear is from a cd-rom drive with disc changing mechanic. The diameter was perfect to fit on the drive shaft without changing/cutting the chassis.
Overall gear ratio is 12 : 1
pinion gear (motor) 9 T
spur gear (power shaft) 25 T
pinion gear (differential) 8 T
differential gear 35 T
The ratio between pinion and spur gear is 2.77 (25T / 9T), which is near to the ratio 2.67 (34T / 12.7T) calculated by "Hooters Driver" in your "get my motor burnt" thread
I did not change the pinion gear yet, because the car goes pretty good, almost to fast
@Alexman
Here are some thread's for you:
raising the chassis http://www.tinyrc.com/forums/showthr...threadid=13599
power shaft http://www.tinyrc.com/forums/showthr...threadid=12707
tires http://www.tinyrc.com/forums/showthr...threadid=13880
Maybe i will make a "how to?", if there is enough interest. But i have to do more real offroad testing, to be sure that everything works well. I already changed the steering, cause i broke two sub-micro servo. Now I am using a Hitec HS85 with metall gear and a servo saver from the Hpi Micro. I hope that this combination performs better than the one shown in the pics. But something else will break - i am sure
@Cian
Thank you.
But, most (if not all) of the mods i have done, were already posted in this forum. I had some of the ideas too, but the posts of the "mini-x masters" help me a lot - especially in avoiding mistakes. So the honor is not on my side. Maybe with my next mod
diets - 6T pinion gear and hill climbing is no fear
Old 11-05-2003, 08:06 PM
mini-eX-Driver
what electronics are you using, and can you post a pic of your motor mount
soon to be
novak xxl receiver
hpi micro mod
5 2/3a zapped cells
xmod suspension
Old 11-05-2003, 08:41 PM
@3series takumi
receiver: jeti rex 5
esc: gm purple sx3r
servo: hitec micro servo hs81MG (in the pics you see the my first attempt with a sub-micro servo - not recommended, will break)
The motor mount consists of two aluminium bars. Screwed to the chassis at the position where the on/off switch normaly should be. I have drilled two holes in the motor case and cutted "Gewinde" (i don't no the correct english word - "holes" for screws), as they are in bigger (180, 300, 540, etc.) motors.
The shape of the aluminium parts are modified for a perfect fit to the chassis and the motor.
diets - it look like some more polishing is necessary
Old 11-05-2003, 09:35 PM
mini-eX-Driver
you are the man. i hope you dont mind, i need to use that type of motor mount on my next mod. looks like it will work perfect
one more question for you, where did you get the 5chan receiver from. that thing looks leet.....i could add an extra servo to raise and lift the x. Hit Switches!!
soon to be
novak xxl receiver
hpi micro mod
5 2/3a zapped cells
xmod suspension
Old 11-06-2003, 11:23 AM
@3series takumi
The motor mount works, you should try it. The only problems is, finding a spur gear that will fit.
I have got the receiver from my LHS. In my country it is available in 35 and 40 Mhz. Attention - it is a FM receiver.
Here is homepage of the manufacturer. Raising and lifting - that's cool. I will use an additional servo for my 4x4x4 project.
diets - got 2 new mini-x today
Old 12-15-2003, 08:17 PM
Thumbs up steering concept improved
After breaking the servo gears the second time
I decided to improve to whole steering concept
must haves
A Bigger servo with metal gears and ball bearings
A servo saver
Hitec HS 81 MG as i use in my HPI Micro RS4
with HPI Micro RS4 servo saver
diets - hopes that it won't break anymore
Old 12-15-2003, 11:42 PM
mini-eX-Driver
dude that is one leet steering setup, i would do the same if i had the room. a servo saver would be nice
soon to be
novak xxl receiver
hpi micro mod
5 2/3a zapped cells
xmod suspension
Old 12-16-2003, 11:37 AM
I have enough room.
I had to put the esc and the receiver on top of the battery pack. I needed some extra room, where the esc and receiver are usually placed, because of the big tires.
So now, there is plenty of room for a real big micro servo
diets - to steer or not to steer
Hard plastic Baja bug body fovea3d Micro-T Gallery 5 07-26-2009 08:21 AM
Baja Bug..... DarkTari Bit Char-G / MicroSizers 0 01-27-2004 10:23 AM
WTB vw bug body isk8blind For Sale/Trade 6 06-04-2003 10:01 PM
baja or Monster Baja Spanky Bit Char-G Mods and Projects 18 04-06-2003 02:22 PM
My Baja VW Bug (Johnny Lightning Thunderjet) brianpipa Bit Char-G Parts and Hop-Ups 0 11-11-2002 09:42 PM
