10-21-2003, 10:18 AM
Dos Questions Por Favor
2 questions
1. What are U-Joints and what are they usded for?
2. Will any AM Tx transmit on the AM X-tal that it has installed?
Like if i put an Non-27MHz Xtal in a traxxas radio will it transmit on that freq?
10-21-2003, 07:01 PM
don't know really how to explain u-joints, but on the radio, yes I belive so, but rande and glitchyness will be alot worse and you will probably be breaking a law (or several) and there is no way your going to get a traxxas revicer in one of these.
10-22-2003, 06:36 AM
im a micro daddy...
ujoints(universal joints) are used when the drive train needs to go thru any angle more than straight,in effect it lets you "bend" a straight bar while still allowing it to turn,this is needed on a steering assembly when the front wheels are powered by a motor.
dave
10-22-2003, 10:59 AM
I know i cant fit a traxxas reciver in it, but i can use the transmitter and transmit to a GWS mini reciever right
10-22-2003, 03:53 PM
Proud to be Pinoy :)
:ö: according to my dictionary, a universal joint is a joint or coupling that allows parts of a machine not in line with each other limited freedom of movement in any direction while transmitting rotary motion. Also called universal coupling
about your radio... i heard somebody tried using different frequency on a 27mhz AM radio and did well.. but i suggest you just use what the radio requires so you won't have any trouble
-æ
hehehe
10-22-2003, 10:49 PM
Hitec makes channel conversion crystals, i was thinking of using their Feather 4 Rx (about same dimensions as GWS 4-channel) with the Hitec crystals in my Traxxas Tx
