10-11-2003, 02:47 PM
Xmod Wheel Base & Width ?
Can some one list a few dimmension of the XMods?
* the WIDTH of the chassis outter flush of rims...
* Wheel base lengths? (center front axle to center rear axle)
I need to know how well if at all the bodies may or may not fit my 4WD Mini-Z Chassis... (comming soon, but likely too late now that the xmods are 4wd). I want to make these bodies fit my chassis design as well as the Racer and Overland bodies... even if it needs a kit to fit the rear body posts.
10-12-2003, 08:56 PM
Wheelbase is 3 11/16" long, center to center. Width is 2 5/8" from outer rim to outer rim. I'll try to get a pic up tomorrow showing the underside of the stock body, showing the two mounts. There's a slot-mount in the front (the chassis has a tab that slides into the front first, then has a catch-style hook in the back that it comes down and hooks with in the back.) hard to describe in words. hope it helps!
10-13-2003, 04:04 PM
mini-eX-Driver
does anyone know the diameter of the rims? and or width! curious about fittin some miniz tires to that thing
soon to be
mini cooperS (bmw) mini-x
novak xxl receiver
lrp quantum micro esc
hpi micro mod
5 2/3a zapped cells
novak 10v 4700u power cap
xmod suspension
xmod wheels and tire upgrade
10-13-2003, 05:27 PM
if no one beats me to it, I'll measure tonite. (and I'll try to get that mounting pic too)
10-15-2003, 01:58 AM
So its the same as a Mini-Z (MR01) in the LONG setting  well that solves the wheel base problem... the body will fit... but how does the side/front mount? I should be able to adapt them easily... to my AWD chassis...
10-25-2003, 04:39 PM
mini-eX-Driver
now i know that there are 3 different wheelbases, what is the size of the longest one (the skyline i am assuming)
soon to be
novak xxl receiver
hpi micro mod
5 2/3a zapped cells
xmod suspension
10-25-2003, 05:03 PM
3-3/4"
10-25-2003, 05:27 PM
the front mounts the same, you will just have to add the pieces on the sides of the body to fit a z, not sure how the overland bodies are though.
