Old 10-01-2003, 04:29 PM
ZipRC's Avatar
ZipRC ZipRC is offline
Modder-Eater
Uber Help Needed w/ Turning Radius.
I'm so sad ...Yesterday, I bought a second car, and it was working GREAT, no problems. Then, when I was putting it away, I dropped it from about 3.5ft above a wooden floor, and now it's turning radius is the size of a watermelon. I'm having a hard time making deductions as to what it is, because I took off the shell, and examined the PCB and the chassis, and everything looks the same as the other car...any tips as how to fix this? or to fix turning radius in general on a car? I believe this might have been mentioned before, but I need a direct answer. Thanks in advanced!
Old 10-01-2003, 04:58 PM
ax0n
is the turning radius crappy in both directions?
Old 10-01-2003, 05:03 PM
ZipRC's Avatar
Modder-Eater
well...its much crappier on one side, but yet, it's crappy both ways. i'm tempted to return it AGAIN for another one.
Old 10-01-2003, 06:07 PM
Jtskty Jtskty is offline
Master Debater
Send a message via AIM to Jtskty
You might have popped out one of the steering knuckles. Or both.
Old 10-01-2003, 06:25 PM
ZipRC's Avatar
Modder-Eater
well...i did quite alot of trying to figure out what it was...and I couldn't figure it out, so i'm just gonna return it.
Old 10-01-2003, 07:26 PM
ax0n
FWIW my SE and most of my other tinies steer one way better than the other, and it's usually got something to do with how freely the front wheels turn on the axles. Most of the time, one spins easier than the other, and that causes problems. I grabbed the axle pin with a pair of pliers, twisted n pulled, then coated it with locksmith grade graphite powder. That helped on most of my cars.
Turning Radius? hschnark ZipZaps SE 3 04-19-2006 06:05 PM
turning radius rob3662 SuperSlicks 0 12-08-2004 04:54 PM
Unequal Right and Left Turning Radius Fix backtrack9 XMODS Mods and Projects 20 10-02-2004 01:32 AM
Turning Radius azn1art XMODS 3 11-06-2003 10:28 PM
turning radius? VuN86 XMODS 0 10-27-2003 10:31 PM
