Old 09-24-2003, 09:46 PM
fireball16789 fireball16789 is offline
to manny donuts
I need help with my car. My car keeps spinning out as soon as i get up to any speed. I was wondering if there is anyway to mak it travel straiter and more percisely at high speeds. Please help me
Old 09-24-2003, 11:43 PM
newbitowner's Avatar
You should get softer tires. Cleaning the tires and floor would help.
Old 09-25-2003, 05:16 AM
MicroSpeed's Avatar
use the stock tires that came with the car, those are as soft as you can get. Only use hard tires for the fronts, thats problably your problem, if you use them for the rear its non-stop donnuts unless you're running on hotwheels track.
Old 09-25-2003, 11:02 PM
boho's Avatar
boho boho is offline
Camera springs
Yeah, microspeed gots the flow. The cars are a little front heavy when they come stock. You'll need to either reduce weight in the front, change the center of gravity, put more weight in the back or a simpler solution is to just give it less traction in the front and more in the back. Example: Slicks in front and softs in back.
i wish my xmod could do mad donuts like that! skklown XMODS 14 01-16-2004 07:57 PM
donuts? 4G63T XMODS 3 10-30-2003 11:30 PM
tires for less donuts eman1 Bit Char-G / MicroSizers 3 01-11-2003 07:20 PM
350Z Donuts usagi20 Bit Char-G / MicroSizers 23 11-24-2002 03:34 PM
2.6 motor results in donuts galore MattM Bit Char-G Mods and Projects 5 09-02-2002 01:08 AM
