Old 09-21-2002, 10:40 AM
Namuna's Avatar
Namuna Namuna is offline
The Compatibility List
The common question with the clones/OEMs and such seems to be "Can I use any of the parts on my Bit"?
Let's make this thread the answer to that question, once we've built a solid base of informaiton...We'll convert this thread over to the Articles section.
If you have any information to add, please post it here. Thanks.
Let's begin (if you're unsure about any of the parts listed, refer to THIS site for a diagram):
AtomicToys: Zcar:
Bodies- No, too short
Heatsink/Motor cover- Yes, 100%
Motor- Yes, 100%
Batteries- Yes, 100%
Rear Axle- Yes, 100%
Idler Gear- Yes, 100%
Rear Tires- Yes, 100%
Front Tires- Yes, 100%
Stabilizers- Yes, 100%
Radio Shack: ZipZaps:
Bodies- No, too long
Heatsink/Motor cover- No
Motor- Yes, just have to keep adjusting till it fits
Front Tires- No, too big
Old 09-21-2002, 10:16 PM
Namuna's Avatar
More about the ZipZaps...
Steering spring- Yes
Front Wheels- Yes, with modification
In order to get my ZipZaps front wheels to work on my Bit, I had to bore out a little bigger of a gap in the holes where the Stabilizer Arms put tension on the wheel arm.
Once the wheels are on, there's going to have to be some adjustment (or rather some Dremeling) of the Bit body (front wheel wells) to adjust to the new, larger front wheels.
Old 09-29-2002, 01:03 AM
SPEED's Avatar
SPEED SPEED is offline
SPEED IS GOOD
Namuna........i was wondering because of the larger tires of the Zip Zap on the front of the Bit char-g were there any problems of it rubbing on the chassis itself or only on the body???
Old 09-29-2002, 02:00 PM
Namuna's Avatar
Good question SPEED,
The answer is BOTH. The front wheel wells can be dremeled to allow for the bigger wheels though.
When making hard turns and holding the steering in the direction, the wheel on the side of the direction you're going tends to get hung-up against the chassis.
So more dremeling involved.
Old 09-30-2002, 10:15 PM
Deadite's Avatar
Deadite Deadite is offline
Micro Maniac
Exclamation Don't hit me
I think this may be a redundant question. Can bodies from char-g's be used on the microsizers. I was just wondering if the connections are the same. I also was wondering if you can just buy the char-g bodies like you can with the microsizers.
Old 10-01-2002, 05:34 PM
tinyrc's Avatar
tinyrc tinyrc is offline
Deadite, yes, you can, they are exactly the same, MicroSizers is just the US name for TOMY Bit Char-Gs!
Old 10-01-2002, 05:45 PM
SPEED's Avatar
SPEED IS GOOD
Hey i found out u can mount the ZZ wheels without any kind of rubbing (from the chassis that is) Instaed of using the ZZ knuckles you can just use the Bit char-g knuckles. This give you the extra clearence you need to clear the chassis. I AM NOT POSITIVE ON THIS but this is what i was told and i'm sure the guy is right because he has done it. So if you would like to mount ZZ wheels on your bit but don't want to grind the chassis try moungint them up with BIT knuckles.
Old 10-02-2002, 05:53 PM
d00kie's Avatar
d00kie d00kie is offline
It's super useless!
Re: The Compatibility List
So their motors are completely different??? Do I need to do anything special besides changing the motor's position (as in rotation)???
Old 10-02-2002, 06:40 PM
Namuna's Avatar
d00kie,
No they aren't all that different (size wise). check out the comparions pics...
http://tinyrc.com/gallery/album18
Old 10-06-2002, 03:15 AM
SPEED's Avatar
SPEED IS GOOD
i was able to fit the ZZ motor in my bit with nor problem. The red motor has lots o torque!! I LIKE IT!!!!!
Old 10-06-2002, 03:27 PM
NewbieBrigade NewbieBrigade is offline
Has anyone tried the wheel mod using the zz's on the bits? If so did u notice any improvement overall such as steering?
Old 10-11-2002, 06:51 PM
Cyslyde Cyslyde is offline
I tried a 2.6 Microsizer motor in my zip zap... it' didn't work unless i pushed it to start it. do i need to do the resistor mod, or is there another mod i need/can do?
Old 10-12-2002, 12:28 AM
truckin'65 truckin'65 is offline
so do the zz motors have more torque then?
Old 10-12-2002, 01:36 AM
MTL's Avatar
MTL MTL is offline
www.d1gp.com
Send a message via AIM to MTL
the only problem with all ZZ rims is that you will have to shave some of your chassis, and maybe even some of your body slightly
on the skyline...i had to shave the front inner fender slightly till the rims turn freely
i dont think theres much handling difference...but it just looks and feels better
Old 10-13-2002, 01:33 PM
mr0072003 mr0072003 is offline
Can someone PLEASE post pics f what thay had to trim on the Chassis
Stock parts list required to convert a Micro-T to a Micro-Desert Truck arch2b Micro-T Parts and Hop-Ups 0 11-12-2007 08:55 AM
Making a "complete" list of all small R/C... Please help! Drake Auldey (All) 0 07-01-2006 06:15 AM
Mini-X Model Body Compatibility List tinyrc Mini-X Parts and Hop-Ups 12 03-15-2004 06:09 PM
list zip zap drag times and mph ml22 ZipZaps 12 02-28-2003 10:21 PM
Crip Cap Master List aero Bit Char-G / MicroSizers 3 12-07-2002 09:47 AM
