Old 09-02-2003, 08:39 AM
Alard Alard is offline
Sherman tank improvement
Is anyone else staging battles on a regular basis?
We regularly have battles involving four tanks. I have been using the Sherman a lot. It seemed to me that this tank was inaccurate. I was missing a lot of shots.
Then it dawned on me. The short barrel on the Sherman made it more difficult to line up shots accurately. The solution . . . upgrade to M4A1(76)W.
This version of the Sherman M4 featured a 76mm gun with a much longer barrel. This particular tank also featured "wet storage" of the ammunition, which reduced the chances that the tank would 'light up' when hit.
I used a piece of heat shrink tube to model the longer gun. The tube was shrunk over a drill bit of the proper diameter, so it just slides on the existing cannon. Painted with it OD.
Now when we battle in "Expert" mode, the Sherman is operated in "Equal" mode, because of the better armor and gun.
That seems more fair!
Old 09-03-2003, 08:54 AM
M4A1(76)W Sherman
Old 09-03-2003, 10:09 AM
Namuna's Avatar
Namuna Namuna is offline
Nice!
Old 09-09-2003, 09:14 AM
Chris_B Chris_B is offline
You may have noticed that the Sherman is the only model which fires on the left side of the turret, the other three fire from the right. If you are accustomed to driving a Tiger or T34, you are definitely going to miss lots of shots as a Sherman driver. Nice pic btw.
Old 09-09-2003, 11:44 AM
On the left
Yes, also, did you notice that the IR aperture is closer to the cannon barrel on the Sherman, than it is on any other tank. Because of this, the barrel is partially blocking the LED on the right side.
Tests have shown that there is a kind of blind spot on the right side of the gun. I compensate by shooting ever so slightly to the left of the target.
Boy, they sure did a crap job on this tank.
new player with Sherman and Russian T34/85 thermo799 Combat Digi Q 0 04-11-2005 08:43 PM
Fix for tank with poor performance Alard Combat Digi Q 11 09-12-2003 10:17 AM
Is my tank dead? Halthek Combat Digi Q 3 05-17-2003 03:11 AM
Tank stopped charging Flawed-logic Combat Digi Q 3 02-03-2003 04:40 PM
Changing Tank ID? Jet Black Combat Digi Q 2 01-21-2003 07:23 PM
