08-24-2003, 10:29 PM
Camera springs
Boo7a, Thanx for clearing that up. It probably is a inductor or something. What about the color of the stripes? Will an inductor's stripes still use silver or gold for resistance accuracies?
Also, I love the torque. The problem is the sticking motion it goes through. When it goes out of range or has any signal interference, it will continue the last command given for a little while. My range on the poor thing is only about 4 ft with tons of interference. Basically, when I hit the go button, it keeps accelerating out of control, doing things that usually resemble acrobatics. If I could get a cleer signal to it with no interference, then I could just start off slower by tapping the go button. But I literaly have to have the antenna inches away from the car to get a good signal.
Sorry I don't have a digital camera right now to get pictures. I've got a friend that has one, so I'll have to borrow it because I think we could all benefit from some more proffessional analysis.
JackD 1. Yes, definately. I replaced the wires again with regular copper coated wires and it's still crazy fast. I did put a die cast ambulance body (I made it) on it for extra weight, and put all slick tires on so it wouldn't grip so much. It's still my fastest dual cell!!!! I just can't control the damn thing. 2. Yes the fricking thing still sticks rediculously. That's why I can't control it.
I went out and perchased a high quality antenna, and I'm gonna try that. I'll keep you guys posted. I don't expect it to work. As far as doing your own dual cell mod to the super bits, I would wait until you can increase the range and get rid of the interference problem. It actually makes me want to cry, because tomy did finally make a very good car this time, but the controller still seems to be a problem, and now they are on different sub-frequencies, so I can't even use a better made controller from a clone.
Sorry PH2, I was just skeptical. I know you're much better at this stuff than me. I hope I didn't offend you.
Can I put an inductor in there somewhere. If that resistor looking thing is an inductor, then could I take that sucka out and replace it with a better, tunable inductor?
08-26-2003, 09:57 PM
boho - the colors on the inductor go according to the following link. http://www.elexp.com/t_induct.htm
The colors on a 27MHz Tango-uniform controller that I have are yel-violet-gold-gold, which according to the table in the link it would be 4.7uH +/- 5%. This is similar to the value of the inductor in series with the antenna in the schematic for a 49MHz controller; i.e., 1uH.
I'm not sure about the newer cars, but my microSizers all came with the antenna toward the drivers side rear of the PCB; it is then routed to the front of the board with a knot tied in the wire and held in place by a retainer clip on the chassis, then routed back along the PCB to the rear of the car where is exits the car. I got some extra range out of undoing the knot, then routing the wire straight out the back of the car. My thougts were to get the antenna away from the board as soon as possible. It is an easy fix ... give it a shot. After fixing the antenna, tune the receiver again using the variable inductor (choke).
The sticking is the signal from your transmitter being attenuated by free-space and then reaching the controller down near the minimum triggering level (sometimes referred to as MTL). This cut-off is not a brick wall, it rolls-off, so statistically some of the signal makes it through and some does not; thus the stuttering, sputtering, sticking ... what ever you call it.
The reciever is prolly doing some DSP (digital signal processing) to smooth out the response of the car. With a faster motor the car now has more momentum and does not stop on a dime.
What you (and others) are doing by putting those 42,000 RPM engines would be analogous to putting the engine from a NASCAR into a Geo Metro ... it will go fast as he- (heck), but don't try to turn ... you'll end up on your back wondering what the he- (heck) just happened. By turning I mean, turn the wheel full right as quick as possible ... this is how the steering control works on the microRC's. If the cars had proportional control, then the car may be more controllable ... however, someone will find the 75,000RPM engine to make the car uncontrollable again. Stiffer suspension may help as well ... microSizers have a kit with three different steering control arms, use the stiffest ... I haven't tried it, yet.
I am going to make a thread on proportional control ... please check it out.
regards,
bigAL
08-26-2003, 11:07 PM
Camera springs
Hey, thanx for the link. Now I'm almost positive it's an inductor.
I already replaced the wire in the car with CAT5 and it's away from the pcb as well.
The sticking motion isn't from speed, it's from continual acceleration. If I tap the go button continualy I can get up to speed with more control, but I have to be about a 6" away to do this. As soon as the car gets farther away it gets interference and starts to continue the last command given. I.E. accelerate and left, or back, or just accelerate, or etc., etc...... The problems insue because it has so much torque that it will do a wheely with so much power that when the back of the car hits the floor it jumps in the air uncontrolably. If I could accelerate slower, then I wouldn't have a problem, but because it follows the last command when there is interference then it will continue to accelerate causing the control problem. The actual turning and moving is great, as long as the is no interference or you don't go out of range. The actual range is 4~8ft.
I've tried just about every range mod there is, that I know of. I listed them previously.
And yes, I tried the new high quality antenna for the controller. Didn't work out any better. I'll continue to fiddle with it though.
08-26-2003, 11:29 PM
dude,
eliminate the interference. If it is other bit's ... well, if they are boosting the power from their transmitter ... tell them to stop.
ph2t mentioned that boosting the power of the controller is not the answer to increased range. The rcvr's don't have very narrow selectivity bands so if you are at 27MHz and they are at 35MHz with boosted power ... well they are getting into your rcvr. Tell them to stop.
If this problem occurs with no-one around then try to find the interference source and eliminate it. This may take some doing, basically start turning things off until the car performs better. BTW: I have a dead spot near my frig. (i.e., car sputters and stops at the frig ... maybe it's hungry) and dish washer (not sure why the wife is radiating EMI).
If you cannot find the offending electronics ... try a to move away from all sources ... including household wiring. The wiring in your house radiates all kinds of shi ... stuff.
If the range is bad, even on the moon, then perhaps the car/control combo is frilled. Purchase a new one.
I had a microSizer I just could not figure out why the range was crap ... it now resides in a plastic baggie, to be used for examination of components and general parts bitc ... h.
good luck.
08-28-2003, 12:21 AM
Sometimes the car's motor makes the interference...
I found that putting a .1uf ("104") capacitor across the car's motor wires will take out a lot of the stutter action. Most cars have this capacitor on the board already, but some don't, and those that do have it may be running a motor that makes a lot of electrical noise, more than existing capacitor can supress. Adding another one across the existing capacitor should help.
08-28-2003, 02:59 AM
Camera springs
Well, I've run the car about everywhere. It's not other people either. I also have another superBCG that has the exact same problem. I ended up swaping the PCB on that already.
It could be the motor. When I put the 1.6 back in, the range w/o interference extended to about 6 ft. The interference range was about 8 ft. Either way, the range is still crap. I'll probably try that cap trick to see if that helps.
I'll keep hangin on to the car, but I'm beginning to give in to the thought that Tomy has jinxed these new supers.
