08-24-2003, 08:39 PM
Blitzer Sonic
How do you fix this?
Broken car antenna.
08-28-2003, 06:50 PM
I bought a new one. They are pretty cheap, But you could also Get some Music wire, and make custom ones.
Xmod Customizer
09-01-2003, 10:02 AM
11-09-2003, 05:00 PM
Brownie Cheesecake
I just had some extra wire laying around and used it. It was rubber insulated, so it won't get fryed in the batteries. I just bent the end into an "O," connected it and coiled it up inside the body. The cool thing is, I've never had to use entry tags, since I put it in.
11-09-2003, 08:40 PM
I've heard that some people made their own antenneas with some wire.
12-06-2003, 02:07 AM
when the antenna on my ol broke i coiled up around 2ft of fence wire inside the body and left just enuff to make it look real with the no taller than the roof sticking out and nearly 2ft coiled up inside it i gained some rang from it and never broke it again drilled a hole just under the right front pilllarand threaded an ince thru and secured it from the inside with duct tape tried elec tape and nearly fried the fet switched to duct tape and held much better and looked more scale
In my garage, X-mods and Mini-Z are not competitors. Both get stuck just as easy, pull the same amount of weight and are equal on fuel. Why be picky?!
