Old 10-01-2002, 08:33 PM
dinkywinky dinkywinky is offline
Bit Char-G idiot
Angry ...bit problems...
i can never start up my bit when i put the car on the charger it would work good then after not using it for 3 to 4 hours i would want ot race it and it wouldnt start not even on the charger i tried a new battery and it worked fine but then in 3 to 4 hours it wouldnt work i tested on my friends microsizer if it was the battery but it wasnt can anybody help me please
Old 10-01-2002, 08:36 PM
datamonster datamonster is offline
I'm with stupid^
Send a message via AIM to datamonster
the BC-G/Microsizers batteries discharge themselves when not in use.
Old 10-01-2002, 08:38 PM
Bit Char-G idiot
i know but i would charge them up again and it still wont work
Old 10-01-2002, 09:23 PM
jets jets is offline
make sure the switch is set to on before you attach the bit to it otherwise it will not charge. make sure the LED illuminates after you attach it and it should shut off after 45 seconds fully charged. if that doesn't work, throw it out the window and try it again
(the last part was a joke)
Old 10-02-2002, 08:12 PM
Bit Char-G idiot
Talking
i found the problem the metal tabs under the car was not lined up properly and it wouldnt charge sorry my mistake
Bit Char-G: FAQs (Updated: Jan 6th, '03) Namuna Bit Char-G / MicroSizers 15 08-14-2003 10:04 PM
Bit Bid problems. tarnjit Bit Char-G / MicroSizers 0 12-03-2002 01:04 PM
problems with new wrx tomy bit 1coolskyline Bit Char-G / MicroSizers 9 09-21-2002 06:10 PM
just got my 1st bit char-g... has problems turning st5150 Bit Char-G / MicroSizers 7 09-17-2002 04:39 PM
