Go Back   TinyRC.com > 1/64 and Smaller > Bit Char-G, MicroSizers, Z-Cars, Clones > Bit Char-G Gallery
Old 09-23-2002, 01:17 PM
323iT's Avatar
323iT 323iT is offline
i haven't done that and i don't think i will. because if you use larger front wheels, i would guess that the steering response won't be as fast because of the larger contact patch to the ground and the extra weight of the larger wheel...
but i could be wrong since i didn't do that mod. just my "educated guess"
I got bigger and wider wheels/tires on my 323i and its harder to turn now. but more stable at high speed and corners
Old 09-28-2002, 12:47 PM
DriveWRX's Avatar
DriveWRX DriveWRX is offline
Lightbulb Spacers
Speed,
I'd answer you earlier but I was on vacation!
Anyway, to asnwer your question about spacers...
I used small diam. aluminum tubing made by K&S, I think (avail. @ your LHS). Just cut it to the lenght needed and slip it over the axel, between the hub and the chassis.
Oh, by the way, cut the tubing using an X-acto knife. Press down gently and roll the tubing under the blade until it cuts (watch it...the small pieces tend to fly off as you cut! )
Hope this helps...If you have any more questions, don't hesitate to ask!
My bB, in the picture, has a whole new look to it. It's now black, is lowered in the front, has a muffler and an opened grill with real mesh. It's still being worked on. I'll try to post pictures when it's done!
-DriveWRX
Old 09-28-2002, 09:06 PM
SPEED's Avatar
SPEED SPEED is offline
SPEED IS GOOD
Hey DriveWRX thanks for the reply!!! Its cool that u asnwered a bit late just glad u answered!! Well thanks for that info i'll try and see if my LHS has the tubes (i'm sure they will). one question though, did you have to do any modifications to the rims themselves??? I noticed that the rim CLOSTEST to the gear on the axle (gear side wheel) has "spikes" that go into the gear itself. I was wondering if you cut/dremeled those out. I also noticed that the rear wheels are wider than the stock front wheels, did you have to do any kind of dremeling to get them to fit? I know that the wheels on the opposite side of the gear has that step on the inner side, and i was thinking that i can just dremel that down so its flush with the outter rim of the wheel. One last question.....what size drill bit did you use??? I've tried several small bits but they seam to big and i end up breaking the center of the rims when i try to drill it (good thing i was testing it out on clone rims . Well thanks again for you help DriveWRX!!!
Old 09-28-2002, 10:47 PM
DriveWRX's Avatar
Rim Mods
Speed,
I did trim down the "step" on the opposite wheel.
I didn't do anything to the gear-side wheel except drill it.
Speaking of drilling ... I used a really small hobby drill bit and a pin vise. I don't remember the exact drill size but I'd guess 60. (These items can also be found @ your LHS). When drilling with a pin vise, use just enough pressure to remove material and go slow. Too much pressure will cause the "blow out" you mentioned.
I didn't even notice the the rears were wider than the fronts!
Honestly, I would do this mod only for looks. You loose a lot of turn radius because of the big wheels up front!
Glad I could help!
Old 09-28-2002, 11:35 PM
SPEED's Avatar
SPEED IS GOOD
hey DriveWRX thanks alot for the help, i may not be doing that mod then if it craps out the turning radius (well maybe for looks ) I'll try adding on some Zip Zap wheels. How much of a loss in turning radius do you loose?
Old 09-29-2002, 12:00 AM
blacksabbath070's Avatar
blacksabbath070 blacksabbath070 is offline
IRON MAN OF BIT RACING
you dont
i put on teh zipzap wheel on my bit today and you dont loose any turn radius at all in fact it makes the turn radius better because the front wheels act like a differential since the wheels are bigger then regular in the front when you turn left your left wheel catches on part of the bit and stops the right wheel willl keep trying to move so you take extremely tight turns get what i mean? i decided to leave teh zipzap wheels on my bit because i like the turning radius it wont work well on the skyline body too well the lancer body seems to have the best wheel clearance
MY NEW CUSTOMIZED BIT:
red ae86 with zipzap spoiler
carbon fiber hood
3.8 motor (well, it doesnt want to run now)
qfm springs
back wheels on front and back
8.25:1 gearing
rare earth magnet steering
Old 09-29-2002, 01:12 AM
SPEED's Avatar
SPEED IS GOOD
What do you mean "catches on part of the bit"??? Does it catch the bits chassis or the body??? I don't want the wheels getting locked up on anything. If its the body that's ok...i can always dremel some stuff from that, but if its from the chassis, i don't want to start dremeling that. So can u tell me where it "catches" thanks!!!
Old 09-29-2002, 01:39 PM
ok
it catches on the chassis it doesnt effect anything with speed why dont you just try it out for yourself you cna always put the original wheels back on if you wnat try it see how youy like it
carbon fiber hood
qfm springs
8.25:1 gearing
Old 10-20-2002, 01:42 AM
rmyc's Avatar
rmyc rmyc is offline
Perfected Bit Modder
i put a lego tires on my bit..some how
it was phat..(.for a tractor thou)
i'm trying any thing i could find on my bit....leds..tires.white-out..etc) it's comming cool
right now i'm cutt'n up dicast cars to back body kits..will post soon
the dynamics of drifting bengali548 XMODS Mods and Projects 5 01-06-2007 09:27 PM
Great Idea In Saving or Strengthening Your Front Axle Steering Hubs.. MicroRCracer XMODS Parts and Hop-Ups 3 02-09-2004 04:40 PM
I put ZZ front wheels on my bit.. VDOGG Bit Char-G / MicroSizers 13 10-16-2002 09:10 PM
ZZ rear axle wheels on front of BIT? Also willing to buy a set of front ZZ wheels. SPEED Bit Char-G / MicroSizers 0 09-27-2002 07:40 PM
front wheels striderpunk Bit Char-G / MicroSizers 1 08-14-2002 09:47 PM
