Old 07-10-2003, 09:24 AM
CheeseWarfare's Avatar
CheeseWarfare CheeseWarfare is offline
Title? Whats that?
Send a message via AIM to CheeseWarfare
Hmm... Easier effective dual cell? Could be!
Check this: http://www.zipzaps.com/zzTips.asp go to Add Run time to your Zip-Zap I'm thinking of doing that but wired for speed. Do you think it will work good? And also I'm scared to flip the PCB any tips on the internal? If it works it will be my first dual cell .
<---Signature Begin--->
Go away!
<---Signature End---->
My XMod:
Black Civic:
-Broken, parts in the mail.
Old 07-10-2003, 02:13 PM
charliebrown's Avatar
nope it won't work. They forgot to post how to charge it properly and second of all it won't extend the runtime, only puts out more voltage
Old 07-10-2003, 05:02 PM
Title? Whats that?
So how do you charge it properly?
Go away!
My XMod:
Black Civic:
Old 07-10-2003, 05:18 PM
AUDI-TT's Avatar
AUDI-TT AUDI-TT is offline
XMOD AUDI TT (my wish)
if u wire them in parallel then u can charge it easily by chargin the car 3-4 times before running it. But if u wire them in series u gotta deliver more voltage to the batts so ud have to make a custom charger with 3-4 aa or aaa batts.
Old 07-10-2003, 06:38 PM
Queso's Avatar
Queso Queso is offline
tiny rc racer
so you're saying if you want it faster wire them in series?
"If I had a bike it would have mad pedals"
Old 07-10-2003, 08:04 PM
Title? Whats that?
No for more speed you gotta wire them paralell I'm gonna try this mod tommarow and Ill tell yall how it works!
Go away!
My XMod:
Black Civic:
Old 07-11-2003, 08:18 AM
I hope you're kidding with us, because if you're saying that for real, prepare to be disappointed.
Wiring batteries in series puts out more voltage. Wiring them in parallel gives you more battery capacity. So, More power getting put out means increasing the juice delivered to the motor rpm , and putting out more mah means more time before the motor stops.
Old 07-11-2003, 10:33 AM
Title? Whats that?
Okay I'm confused now lol. So if I wire them Negative to Postive and Postive to Negetive it will give me more power? But thats exactly what they did and they claim it gives more runtime. And if I wire the + to + and - to - it gives me more runtime? As soon as i figure this out Ill do it. Lol its ur fault im confused charlie!
Go away!
My XMod:
Black Civic:
Old 07-11-2003, 01:29 PM
Oh good grief!!!! You take the battery inside the car, tape one end of the foil to it's negative side and tape the other end to the positive end of the other battery. Then tape a foil strip to the negative side of the 2nd battery and tape the other end.....hang on I'll post a pic. The gray shaded area is the foil and the black area is the tape
Old 07-11-2003, 03:03 PM
AUDI-TT's Avatar
here i think this will help. (i hope)
and for the charger, go buy a 4 aaa batt holder and stick a chargin pod thingy on it. Charge ur duall cell for about 1 minute. Thats only if u choose to do series wiring tho. If u do parallel wiring u dont need a new charger, u just gotta charge it 3-4 times over and over to get the batts full.
Old 07-11-2003, 03:48 PM
Title? Whats that?
Is a duel cell wired in series usless without a special charger?
Go away!
My XMod:
Black Civic:
Old 07-11-2003, 10:19 PM
NatakuARN's Avatar
NatakuARN NatakuARN is offline
Anime RPG Nut
Is there a link to a guide that shows how to do a dual cell and controller mod for the purpose of providing more voltage?
Old 07-12-2003, 06:42 AM
strider_mt2k
Guys, try doing a Google search for series and parallel wiring.
There are TONS of basic electronics sites where you can learn how this stuff works for real.
Old 07-20-2003, 03:58 PM
ZipRC's Avatar
ZipRC ZipRC is offline
Modder-Eater
Send a message via AIM to ZipRC
is zipzap antennae wire conductive with the batteries? Because i don't wanna buy any copper and i have like 12 ZZ/Clone antennaes lying around that i could cut the insulation off the ends.
Old 07-20-2003, 04:41 PM
You'd have to solder (or shrink wrap) the wires to the batts. but it should work.
Or you could try the Layman's Dual/Tri Cell mods. Somebody is even working on a Layman's Quad Cell right now!!!
Layman's battery mods are GREAT for performance. They weigh pretty much the same, if not less, and that doesn't affect the weight of your car. So, you would have more power.
Easier Dual Cell alexnessie Bit Char-G / MicroSizers 9 05-06-2003 02:36 PM
Laymans dual cell vs. traditional dual cell Zephyranthes Bit Char-G Mods and Projects 6 02-18-2003 06:12 PM
Dual cell mod and discharge problem (cell reversal). kenny_dilger Bit Char-G / MicroSizers 1 12-17-2002 10:23 PM
