Old 03-09-2003, 03:38 PM
2fast4u 2fast4u is offline
Send a message via AIM to 2fast4u
Unhappy how
Originally posted by TypeZer0
umm, that is so off topic, y dont you make a new thread about finding cheap hop-ups in the apropriate forum rather than posting replies to a thread that has nothing to do with what you're discussing
mini z:ferrari f-40
xmod:body undecided
Old 04-04-2003, 11:53 AM
rwinder's Avatar
rwinder rwinder is offline
Riiiiiight...
Field Effect Transistor - lots of electronics use this type of transistor, and no, it's not an "American thing."
Originally posted by dieselboy
whats is a FET and what does it do? I'm fairly good with electonics but never heard the term fet before. Its probably an american thing
1 Civic X-Mod AWD 1 RSX X-Mod
2 MicroSizers 3 Shens
5 Precious 1 ZipZap
2 LXX Boosters 1 H1 Hummer
2 Bit chassis in process of mod'ing
2 Auldey 1/32 2 Auldey 1/16
1 Team Losi XXX-NT
Old 04-09-2003, 10:49 PM
Calsonic_racer Calsonic_racer is offline
MASTA POOOOOOOOOOOOOOTANG
exactly how hard is this mod? is soldering required?
MICROSIZER PRO: 2 SPEEDS, 1.3 NIMH, 49 MHZ, SKYLINE R34 GTR custom paint, pull back wheels, blue head lights
MICROSIZER SPORT: 1.3 nimh, rest is stock
panther= 2.4 nicd, rest is stock
MEGATOYS rc: rest is stock
bitchar-g: rest is stock
Old 04-12-2003, 10:43 AM
Talking hey!
hi guys ive got a couple of new mods like if u want to change the weight on ur tinyrc u can use congi peises, inside there are metal shavings that can be put into the car and also i got lighting under my zip all u do is drill a small hole in the bottom but that is big enough to hold the led(s) snugly and then just follow the prosedure for standard led installation its very cool just dont lower the led to far to the ground or that will slow u down and try not to over do the weight although the right amount of weight will make u go faster it is also better to wrap the shavings in tape so they dony rattle or get in the way if u got questions email me at ilyakoch00@go.com
mini z:ferrari f-40
xmod:body undecided
Old 04-15-2003, 06:39 PM
Cool check it out!!!!
hey guys, yo tinyrc, im new u run this place right?
u should have more stuff on zipzaps like on the parts shop u should include zipzaps. plus whens the next contest ive got a black porsche with neon lights, twin tail pipes and i found a special wire that is stiff for the antenna pretty cool huh?
mini z:ferrari f-40
xmod:body undecided
Old 06-08-2003, 06:42 AM
teamoutburst's Avatar
teamoutburst teamoutburst is offline
TINY RC RULEZ!
How did you find out where the resistors were in the circuit board?
My Car:
Old 06-08-2003, 09:26 AM
TINY RC RULEZ!
Actually dont answer that, i found out myself. I have managed to put together a 'max toque mod' for a bit char-g. Your board may be differently set up because i am using a Panther as the model. Anyway the resistor is simply inline between a pin on a black rectangle thing and the motor. You quite simply put a resistor of the same value of the resistor marked X on top of the other resistor so the current has two resistors to go through, therefore halving the resistance of the resistor marked X. You should now have a sandwhich of two surface mount resistors, You can still get the PCB case back on though because they are so small. It now wheel spins when ever i go forward and slam it into reverse, when i didnt have this mod it used to slow down rather than wheel spining and then go in reverse.
My Car:
Old 06-11-2003, 05:17 AM
SKYLINESrule's Avatar
SKYLINESrule SKYLINESrule is offline
Send a message via AIM to SKYLINESrule
Noooo, the pic didn't work
The only replacement for displacement is technology
Old 06-13-2003, 12:10 PM
TINY RC RULEZ!
dont know what wrong with that then it should work
My Car:
Old 06-15-2003, 02:14 PM
Char-g Ace's Avatar
Char-g Ace Char-g Ace is offline
I need to change my Title
nice
4 Bit Char-g Failiers
1 Microsizer
3.8 motor
Duel Cell sucess
Celica body
Old 07-04-2003, 07:55 AM
GT Racer's Avatar
GT Racer GT Racer is offline
Send a message via AIM to GT Racer Send a message via Yahoo to GT Racer
Does this Tourqe thing really work?
Do you feel the heat yet?
Old 07-04-2003, 12:17 PM
TINY RC RULEZ!
yeah, it is quite a good improvement, it can wheelspin now, it used to slow down with out skiding now it wheel spins, great for drifting.
My Car:
Old 07-06-2003, 09:01 PM
ricky ricky is offline
Dude we neeed pics of this on a bit / ms pleaseeeeeeeeeeeeeeeeeeeeeeeeeee
Old 07-07-2003, 01:14 AM
TINY RC RULEZ!
i dont have a bit charg or a ms
My Car:
Old 07-29-2003, 09:18 PM
charliebrown's Avatar
QUESTION!!! Does this increase speed or JUST torque? And I was wondering, instead of doing this, could you just solder some wires???? Get a closeup of the pic of the mosfet-modded car at RCmod. (Hey, THAT site didn't get filtered LOL) you will see some blue wires and where should I solder on the ZZ????
RMYC's extra torque mod rmyc Bit Char-G Mods and Projects 10 07-26-2003 12:04 AM
torque mod help CRUMB ZipZaps 0 02-27-2003 08:44 PM
max torque mod for bits? dieselboy Bit Char-G / MicroSizers 0 01-27-2003 08:33 PM
