Old 09-21-2002, 09:46 AM
dinkywinky dinkywinky is offline
Bit Char-G idiot
Angry 20 second charge
MY car is messed up it would only charge for 20 seconds and then the light will turn off so when i race it it would run for about a min then just die befor i had problems with my charger it wouldent turn on can someone please help
Old 09-21-2002, 11:42 AM
Namuna's Avatar
Namuna Namuna is offline
Do you recharge the car often, even though the battery isn't fully discharged?
This sounds like it may be something with the car battery.
Old 09-21-2002, 02:05 PM
tinyrc's Avatar
tinyrc tinyrc is offline
dinkywinky, when was the last time you replaced your charger batteries? Try that first.
Old 09-21-2002, 08:02 PM
Bit Char-G idiot
tinyrc i replaced them yesterday and i have two car batteries i tried them both it still didnt work
Old 09-21-2002, 09:47 PM
tinyrc's Avatar
Do you or a friend have another transmitter you can try? Does the car work if you control it while it's on the charger and the light is on?
Old 09-23-2002, 08:02 PM
Bit Char-G idiot
i have a friend at school ill try his and yes my car does run when its on the controller
Old 09-24-2002, 02:06 AM
QFM Racing's Avatar
Moderator - Modifier
QFM will be selling an upgrade component to extend your default controller charge time to 90 seconds, as 45 seconds usually doesnt charge the stock battery to full capacity. It should be available in less than 2 wks. (requires soldering).
http://questformadness.com
Old 09-24-2002, 02:23 AM
dumboi07 dumboi07 is offline
Send a message via AIM to dumboi07 Send a message via Yahoo to dumboi07
may not really deal with this but...
does anyone else have a booster control? when ever i turn my booster control on the charge light comes on, then after a regular charge would be finished the light turns off. anybody else's do this?
Old 09-24-2002, 05:29 PM
Bit Char-G idiot
i found the problem one of the wires were loose in the charger and so sometimes it would work and sometimes it wont its back to normal now
Old 09-28-2002, 12:22 AM
jigoku jigoku is offline
My booster controller has been doing the same thing. I have nimh batteries, so usually charge my cars twice before running them, and have noticed that if i take the car off when its not timed out then the light stays on when the car isnt on the charger, where before it would turn off as soon as the car is pulled off.
charge rate?????????? fisherman2000 ZipZaps Monster Truck 1 03-14-2006 10:27 PM
FYI:Motor Works (clone) charging base will charge dual and triple battery setups. Clint Bit Char-G / MicroSizers 0 02-17-2003 04:09 PM
My LXX won't charge Nenox Bit Char-G / MicroSizers 3 11-30-2002 06:16 PM
charge time sipsap ZipZaps 5 11-25-2002 11:32 PM
