Old 06-25-2003, 08:36 PM
CheeseWarfare's Avatar
CheeseWarfare CheeseWarfare is offline
Title? Whats that?
Send a message via AIM to CheeseWarfare
Really wierd rear axle prob.
This has been like this for awile and I'm sucking it up to ask the pros.
Okay on my rear axle on the motor side for some reason when I run the motor it will go but the the motor side slips and doesnt touch the gearing. When I put diffrent Gear seats than it doesn't slip was often or fast. Plz help
<---Signature Begin--->
Go away!
<---Signature End---->
My XMod:
Black Civic:
-Broken, parts in the mail.
Old 06-25-2003, 10:33 PM
Azimov's Avatar
Azimov Azimov is offline
I process, therefore I am
Sounds like the dreaded wearing out of the rear axel mounting holes over time. Check and see if you have a lot of play on that side where the axel clips in.
Old 06-26-2003, 07:19 AM
Title? Whats that?
Yeah the hole is kinda worn down. What should I do?
Go away!
My XMod:
Black Civic:
Old 06-26-2003, 12:28 PM
cj1267's Avatar
cj1267 cj1267 is offline
CJ's Hobbies.net
Send a message via ICQ to cj1267 Send a message via Yahoo to cj1267
Azimov posted a good idea last time at http://www.tinyrc.com/forums/showthr...&threadid=5185
Old 06-26-2003, 04:53 PM
civic freak's Avatar
civic freak civic freak is offline
Tiny RC Guru
Cool
wrap your axel in scoth tape apply ever how many layers you need but b carefull don't put to much or it wont go trust me ive dun it b4
the whole in the wall is not a tounge cleaner
I LOVE GOD YOU SHOULD TOO!!!!!!!!!!!!!!!!!!!!!!!!!
Old 06-26-2003, 04:56 PM
Tiny RC Guru
i meant scotch tape
the whole in the wallis not a tounge cleaner
I LOVE GOD YOU SHOULD TOO!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old 06-26-2003, 05:47 PM
Title? Whats that?
Its called editing your post Civic Freak.
Thanks for all the help but today i was messing around with it and a wire came of in PCB and then another and then the antenna!I didn't do much to them the soldering must have become weak or something. And I don't have a soldering iron so I cam't fix it. I think my dad will take me to rat shack and let me buy a new one since it died. ::R.I.P. 27 Mhz MazDA RX-8 Chassis, My first Zip-Zap::
Go away!
My XMod:
Black Civic:
Old 06-26-2003, 06:48 PM
faulkbeets's Avatar
faulkbeets faulkbeets is offline
not so bright
Send a message via AIM to faulkbeets
I've only had mine for not even a week and this same thing happened to me... i just went back to shack and they gave me another
Rear Axle Bearing I-luv-Goin-Fast ZipZaps Mods and Projects 0 03-28-2005 01:58 PM
Repairing a worn rear axle retaining slot rfnagel ZipZaps 5 01-22-2004 01:37 PM
Rear Axle Tip nrmcj Bit Char-G / MicroSizers 8 05-18-2003 01:47 PM
heres a simple solution incase your rear axle doesn't snap into the mounting points spikeymike218 Bit Char-G Mods and Projects 18 02-16-2003 09:24 PM
ZZ rear axle wheels on front of BIT? Also willing to buy a set of front ZZ wheels. SPEED Bit Char-G / MicroSizers 0 09-27-2002 06:40 PM
