Old 06-23-2003, 10:51 PM
SSRay SSRay is offline
Best Racing Tires
Whats the best tires for racing?
Micro Sizers:
Toyota Supra (white body from perfection) 3.8 , 9:85:1 , 27mhz
Toyota Celica (body)
(extra engines - 2x 1.0)
ZipZaps:
Fast and Furious Supra
3.4 , 9:85:1 , 27mhz
Fast and Furious Civic
Champagne Honda Civic (body)
Silver 911 Porshe (body)
Old 06-23-2003, 11:17 PM
Ovgron's Avatar
Ovgron Ovgron is offline
I own you
depends, are there alot of tight turns? straightaways? whats the track made of?
1/8 X-Terminator
1/8 Thunder Quake
1/10 Nitro Blizzard
1/10 E.Stampece
1/10 E-maxx
1/10 Evader BX
1/12 Nitro Legends
1/12 Digger 2
Old 06-23-2003, 11:58 PM
2G2SILVERSTRAT 2G2SILVERSTRAT is offline
im rick james bytch
Send a message via AIM to 2G2SILVERSTRAT
i can make you a deal on the 3 diff types of tires and axels,with gears if you check my post in the trading forum
Old 06-24-2003, 11:30 PM
SuperFly's Avatar
SuperFly SuperFly is offline
bitPimp
In general, you want the softest, stickiest things you can find for the rears. Up front, I've found that anything softer than hard tires is too soft. Start with the "hard" tires (dark grey with grooves). If you plow into turns or your radius is too large for your liking, go to medium (black, no grooves) if you are doing donuts or spinning, try taking the tires off completely and riding on the rims (really!) or try the tires that come with HotWheels K.I.T.T. racers (energi)
Old 06-25-2003, 03:01 AM
Smurf Smurf is offline
Lube Master
Send a message via AIM to Smurf
i cut up some grips on pens there made of gel and stick hella! They put alot more power to the ground!
http://www.halffull.net/phast.jpg
Phear my phast motor icon!
Old 06-25-2003, 01:19 PM
Daisycutter's Avatar
Daisycutter Daisycutter is offline
Cuttin' up Daisy
i used my pullback tires all round and they are great! My R32 does tight turns and doesn't flip on a 3.0 , before i got the pullback i just used the bare rims and they were just as great. On a clean marble or stone floor the pullback tires do just great
Old 06-25-2003, 02:52 PM
Pull back? (new to this)
Micro Sizers:
ZipZaps:
Old 06-25-2003, 03:15 PM
Cuttin' up Daisy
Ray, pullbacks are little toy cars the same size as bits, their bodies are designed to fir bit cars. as the name suggests, you just pull em back and let go
Old 06-25-2003, 05:20 PM
TypeZer0's Avatar
TypeZer0 TypeZer0 is offline
0reZepyT
when u guys ride on the bare rims, do u do it to the front or back or both? cuz when i tried it on the front, it plows straight on when i'm on a table and if i take out the rear, i do crazy donuts and with all four tires off i do even crazier donuts
Friends (Joey's Bag)
Rachel: Exactly! Unisex!
Old 06-25-2003, 07:10 PM
SuperFly's Avatar
bitPimp
Riding on the rims is only for the front. This is something you do for a really fast car running flat out on a large-ish track. Basically with tires you're trying to strike a balance between front and rear. For example, if the rear of your car is swinging around and you spin in turns (oversteer), you need to do something to either make the rear have more grip or the front have less grip, or both. If your car plows and doesn't turn as sharp as you like, use front tires with more grip.
I race primarily on a hardwood floor and an enamel-painted floor, both fairly smooth. With a stock setup I spin out way too much, so harder front tires or none at all work best for me. Obviously the grippy-er everything is, the faster you can go. So again, as grippy as possible in the rear (LXX rears or pullback seem to be the best), and then whatever is needed in the front to balance out the characteristics in a turn.
Old 06-25-2003, 08:01 PM
Thanks guys...that really helps alot. I was racing my friend at school, (floor was dirty!!!) I have a 3.8 and he has the 34 nos zipzap motor. He beat out my car, but in the end i still think my car is faster, it was just that my car was going so fast it couldnt grip the floor and it was coming off the floor. Another question. Would racing on the rims mess up the rims?
Micro Sizers:
ZipZaps:
Old 06-25-2003, 08:48 PM
SuperFly's Avatar
bitPimp
Racing on the rims does not hurt them at all. The part that actually contacts the floor is a raised ridge in the middle of the rim. If you put the tires back on, you can't see it. I did a mod a while back where I took the hard plastic wheels from a KIT racer and put them on a bit. It handles great on the right kind of floor.
Day's goodies and Cheap Foam Tires Jazz32 XMODS Parts and Hop-Ups 5 07-20-2006 11:01 AM
lego tires, xmod rims Marius666 XMODS Mods and Projects 19 04-13-2006 08:53 AM
Bit tires vs Microsizers tires Dys70pia Bit Char-G Parts and Hop-Ups 3 12-28-2002 03:34 AM
Carpet racing tires Impreza WR reX Bit Char-G Mods and Projects 5 12-19-2002 11:20 PM
