Old 06-23-2003, 07:30 PM
Fast_Furious's Avatar
Fast_Furious Fast_Furious is offline
Doom doom doom doom doom
Send a message via AIM to Fast_Furious
POTS problem: need help
I was trying to adjust the POTS and i went to far. Now, it wont turn and it will only work right next to the controler.
Thanks
Don't mess with me I'm fast AND furious-word out
Old 06-23-2003, 07:51 PM
PseduoRooter's Avatar
PseduoRooter PseduoRooter is offline
I hate suits!
if it's stuck you could try.... a hammer or something. Seriously though, you could try a smaller screwdriver maybe. Anything to get a better "bite" on the pot.
Old 06-25-2003, 09:04 AM
that might work but the other screwdriver worked pretty good
Old 06-25-2003, 12:17 PM
ib311's Avatar
ib311 ib311 is offline
Promoted to Pleb
be extra careful and use adult supervision, but you could get a razor blade and have it cut into the pot a little and then turn the razor blade and see if that helps grip it at all. it won't shred the top like a screwdriver does. please be careful though and don't hold me responsible if you cut yourself. you mod at your own risk.
Old 06-27-2003, 12:26 PM
ill try that thx
Old 06-28-2003, 10:34 PM
boho's Avatar
boho boho is offline
Camera springs
Also try tuning the pots from underneath. Sometimes that helps me.
Old 06-29-2003, 12:03 AM
nrmcj's Avatar
nrmcj nrmcj is offline
Rice Me
heyy, from okinawa eh boho? lots of BCG stuff there eh?
i tried the POTS mod a while back.. it helped, but on my other cars i cant seem to get it to move. how do you turn it from the underside?
Old 06-29-2003, 12:22 AM
boho's Avatar
Camera springs
Well, when you look at the pcb from the bottom, you'll notice a hole underneath the pot. You should be able to adjust it the same way as from the top. If you still don't see, then I don't know. Maybe my cars are a little different. I'm on a different continent. ?!
Okinawa has some, but mainland Japan has a ton more. I've been able to find up to 6 different bands as well as a seperate frequency for the boost cars (that's 10 usable cars at the same time{slight interference}). That may be old news though?
Old 06-29-2003, 02:57 PM
nrmcj's Avatar
Rice Me
hmm, i see the bottom of the screw when i look at the bottom of the POTS... it's pretty much a smooth, no notches thingy that im not quite sure how to turn. what do you use when turning the top of the POTS..? the best i can do is a toothpick shaved into a screwdriver..
heh, all my Bits are imported here directly from japan, so im almost certain they're the same . hmmm isnt okinawa the chain of islands under the mainland..? the 5th section rite?
Old 06-29-2003, 11:03 PM
boho's Avatar
Camera springs
Mine has notches on both sides to fit the screw driver in. Did you take that gell/mucky crap off?
Yeah, It's part of that chain of islands. Congrats, most people don't know that. I'm not Japanese though. I work in the U.S. military. My home base is here.
Old 06-30-2003, 08:14 AM
strider_mt2k
Exclamation
Be sure to use something non-metallic to adjust it!
Anything metal will throw off the tuning. The minute you remove the tool, it will change again.
Rad Shmack has tuning tools, but you can make one from some plastic if ur good.
Steering problem rody XMODS 1 01-29-2007 10:18 AM
sputtering problem with my new zap... Cool Dad ZipZaps 12 06-20-2003 11:05 PM
Dogbones popping out? No problem. bluemax_1 Mini-X 3 04-01-2003 10:39 PM
Transmitter problem (picture included) ryanhook Bit Char-G / MicroSizers 11 12-26-2002 08:29 PM
Charger clip on PT Cruiser problem Jonny B ZipZaps 4 10-18-2002 03:57 AM
