04-18-2003, 02:56 AM
Mr. Goop
the axle is in my bit.. now its time to mount the motor...
04-18-2003, 06:04 AM
ive got three axels and motors if you want them
04-18-2003, 10:08 PM
I cant stop modding
why did you not just cut off the front of you bit snd the front of the slot car and join them together thats what I would do
this thing going to rip keep me posted
04-18-2003, 10:54 PM
Mr. Goop
im trying to keep an all bit chassis.. i could do that. i could also just extend the bit chassis, about 7mm and it would fit pefect..in fact i still might extend this thing.. i first want to see what 4 cells will do. i still havent got my batterys for it yet..
04-19-2003, 12:09 PM
I cant stop modding
can you post a pic of your slot car the axel looks just like mine but I havent been able to run mine with low voltage like you have
04-19-2003, 03:08 PM
Mr. Goop
i believe the car is an aurora slot car... HO scale. i need to get more batterys for my camera so i can take more pics.. i have also had trouble with getting it to work.. but i cleaned off the contacts on the motor. and double checked the battery contacts and then it was working. you have to have a perfectly good connection for the motor to turn..
04-21-2003, 01:13 PM
Got Mini-z?
real slot car back tires would b great for drag racing.i know this dosnt really have anything o do with this but...it would be..my friend has some that are used but are still very very sticky...like it has glue on it...there about 3/4s of an inch to 1 inch wide... but the axel hole is too big....im bout to go get them soon and put them on my drag car...
04-21-2003, 01:50 PM
I cant stop modding
I was doing to do that too I have a set of them on my desk but I think I will buy kit racers with the black front wheels and use those to mount the wheels
I put the front slot car wheels on a car with the back wheels and lowered it on a kit chassis and it looked way more porportioned
like a real car
I have muscle machine wheels on my car so it doesnt matter to me
04-28-2003, 01:13 AM
Mr. Goop
humm.... well i might be scrapping this plan. i got the motor in the car (bit) but the batterys were just not powerful enough...these motors need a lot more juice than a few 1/3 aaa batterys deliver.. i guess its time to swap out the slot car motor for the BFM. or the motor from my electric toothbrush.. theres more info on this mod in another post something like the BFM 9000...
04-28-2003, 06:35 PM
I cant stop modding
thats a shame I got my motor to finally run off of a 5V pack of AA I bet if you got 2 Li Poly that would be sufficiant
I also could not find the BN 9000 thing I tried searching but nothing came up
I need a battery pack that I van externally carge for my half broken car i wreaked it doing a duel cell so I cannot charge using the standard spots
any Ideas
I 'm thinking maby I might look for a cordless phone pack
or do you know if lithium disposables are strong enough you know for lights in cars I thought I can get them for $1 canadian so I could just not use it as much and use those
The li poly are amazing seeming but I dont trust myself with charging them
06-10-2003, 07:51 AM
the old hot wheeels cars that had a built in 2v compacitator has a slot car motor that is able to run off a dual cell i suggest using that
06-10-2003, 09:05 AM
Mr. Goop
what hot wheels cars are you talking about???
06-10-2003, 09:43 AM
i dont know what there called but there pretty old
06-10-2003, 02:33 PM
what exactly is a slot car?
06-10-2003, 06:15 PM
Mr. Goop
its a car which usually has an armature motor... basically a wound motor with magnets on the side. when current is passed through, the motor it creates a magnetic field which in turn makes it spin...
anyway the cars themselfs have a straight front and rear axle, and a peg in the front middle of the car that goes into a grove on a track. the track has a couple strips of metal on either side of the groove which electricity flows... there are contacts on the bottom of the cars which pick up this energy and propel the car forward.
check out http://www.slotcarworld.com/ to learn more about them.
