Old 11-07-2003, 01:06 AM
itsme
biiig problem...
A few days after I got my SE...well a week or so later my battery started dying faster and faster... Now they last for about a minute with the NOS motor and the lights plugged in. I'm clueless... Help?
Old 11-07-2003, 02:22 AM
Fusion Fusion is offline
Send a message via AIM to Fusion
try putting newer batteries in the your controler. If that dont work return it if not buy another battery and replace it. let us know what happens.
Old 11-07-2003, 06:12 PM
itsme
hmmm
I'm just about to put new batteries in it but can you tell me. Are you able to return a painted body?
Old 11-08-2003, 01:07 AM
nope if you changed the car you can return it. would you could do is buy the same car and switch out the bodys and return the none painted one. I think the new batteries should help that is usually the problem. You could make a test run the car with stock motor and no lights then run it stock with the lights then with the nos motor no lights then nos motor with lights and recored your run times then post them. I know that the nos motor eats up the battery faster as well as the lights. the surface and gears you are using can eat up the battery faster too. what are you runing the car on and with what gears?
Old 11-08-2003, 08:08 AM
viperkilla's Avatar
Re: hmmm
Naw, my friend did that and they said they couldnt take it back since it was painted.
A problem with my mini-x RX and TX Smurf Mini-X 0 12-02-2003 11:32 PM
ver 2 ESC with X-speed problem miketre Mini-X 8 10-30-2003 12:27 AM
sputtering problem with my new zap... Cool Dad ZipZaps 12 06-21-2003 12:05 AM
Dogbones popping out? No problem. bluemax_1 Mini-X 3 04-01-2003 11:39 PM
Transmitter problem (picture included) ryanhook Bit Char-G / MicroSizers 11 12-26-2002 09:29 PM
