Old 07-16-2002, 02:52 PM
ninja ninja is offline
Steering broken?
Just got my Bitchar today, and how much i try the car turns harder when i turn right, if i turn left the car turns in a biiiig circle. I also have to adjust the adjuster under the car to maximum to the left to make the car go in a straight line, it stills draws slightly. Can this be easily fixed?
Old 07-16-2002, 04:58 PM
Theta138 Theta138 is offline
Check the magnets in your front end. How to open up steering compartment
Old 07-16-2002, 05:14 PM
Wedginator Wedginator is offline
I luv LEDs
check the front of the car for metal debris... that is the main cause for malfunction.....
Old 07-16-2002, 06:08 PM
tinyrc's Avatar
tinyrc tinyrc is offline
Also take a close look at the magnet's centering in its holder:
http://www.ausmicro.com/technical/bi...o/DSCN2433.jpg
I've seen them ship with the magnet biased to one side which has a great affect on steering. Pull the magnet out and re-center it, making sure to retain the pole orientation.
Old 07-16-2002, 09:22 PM
ViperKid's Avatar
ViperKid ViperKid is offline
Redneck Drifter
if all else fails you can always send it back
Old 07-17-2002, 01:36 AM
Thanks
Old 07-17-2002, 12:05 PM
tinyrc's Avatar
ninja, were you able to fix it?
Old 01-05-2003, 09:21 PM
mrcdemon
ive been having some steering probs too, when i hit right its like its not sending the signal for about 2-3 seconds, then the turn kicks in. thats just not acceptable. plus i have to push extra hard for it to work. anyone know whats wrong?
Old 01-06-2003, 03:53 AM
Sid Sid is offline
Angry goddamn
i tried i opening my panther clones front part to see the magnet since it was screwed up...the car plaastic just snapped and now i cant put them back...so the cars gone!
45 MHz Nissan Gloria Bit Char-g
Custom Tires (back)
Medium tires (front)
TOMY Bit Racer 2.6 Motor
Broken steering wires bluemonster ZipZaps 2 06-29-2004 12:00 AM
steering wires broken :( -=CrAnSwIcK=- Bit Char-G / MicroSizers 3 12-15-2003 07:09 AM
Steering Wires Broken funkymonkey Bit Char-G / MicroSizers 6 01-14-2003 11:00 AM
