07-24-2004, 05:58 PM
Originally posted by scottyboyfun
Best to use a 12W soldering iron with a fine tip.
Check out my wiring pic, the smd leds are actually there! The wires lead to them!
Sorry for bringing back more then a year old topic, really sorry, lol just found out, but anyways
What if you had a dual cell 150mah battery, or above, and you wired the lights to the motor, well the head lights, and the other rear lights to the reverse on the board, get it? that way forword you0 get front, back you get the red taillights.
09-28-2004, 07:30 PM
Mr. Mod
that would work, but i would suggest smd leds only
Cars:
Zip Zaps w/ 4.2, lego monster wheels, spring susp.
T-MAXX: Up and runnin' with new servo
Rustler: running @ 40mph!
Xray M18: I stepped on it and broke the rear body mount, but it sitll runs....
RCX: It was sweet!
I don't have A.D.D., the icon was too funny to resist...........
10-02-2004, 01:25 PM
what kind of battery did u use??
i want to do something like it tooo but im a total noob at this can u play DRaw a diagram
saying which is hooked on to which please
10-12-2004, 10:21 AM
Originally posted by BCGMan
Thanks, do you know how to make the light active only when you press forward or backward w/out using a switch. Lmk, thanks
Just connect the LED to the motor terminal. The led will lit only in one directon, which one, depends on the polarity of the leds. You can connect 2 pairs of leds, one pair for forward and 1 pair for bckw, just make sure that polarity of the pairs are opposite to each other.
10-20-2004, 09:58 PM
BitPimp
connecting LEDs directly to the motor terminals is one of the stupidest mods ever!!!
The leds should be fed by their own batteries... to switch em on and off: use a transistor to amp the signal, you should use a resistor so you don't take away from the motor, unless you want a really slow bit...
i get my parts off really old computer pieces ie: hard drives, motherboards ect. i super glue them upside-down on a piece of construction paper then solder em. (use enamel wire!!!) then finish it off with sensor safe silicone.
Here ill attatch a simple schematic for all you wanting switched lights. Or if your lazy go and by a Z-Cars... they come with an LED already
Whack!
11-02-2004, 04:54 AM
Originally posted by nasphere
..... unless you want a really slow bit...
Yeah, the insane 2 mA current that the led "eats" would really make the car slow
