Old 02-15-2003, 10:26 AM
Zephyranthes's Avatar
Blitzer Sonic
It's not a BCG or MS chassis though. Would it still work with my controller? I'm probably just going to ask Hobbico for a new chassis. They haven't replied yet, but I emailed them late at night yesterday and it is still early morning here.
Old 02-15-2003, 05:03 PM
JTM's Avatar
JTM JTM is offline
1 4M 70 1337 4U
Send a message via AIM to JTM
keep in mind its a 3 day weekend.
Old 02-18-2003, 02:02 AM
vw_nut vw_nut is offline
yea, this happened to me too ... using CA on the tab won't do the trick ... the part where it touches the chassis is too small ... so do this ... get a an "L" shaped platic tab so you can CA it on the chasis (got mine from an old tamiya model) ... then drill a hole for the metal lock ... works like a charm
Old 02-18-2003, 03:50 AM
btlmr's Avatar
btlmr btlmr is offline
TinyRC Chief
Send a message via AIM to btlmr
Adding the CA glue to just the surfaces that touch isn't enough. Agreed.
I glued it on left it for an hour, then I added a lot of glue and built it up. The next day I sanded it back where required. I would say is stronger than original now.
butler
_______________________
Size clearly isn't everything...
Old 02-18-2003, 11:04 AM
MST3KPIMP MST3KPIMP is offline
what you need is kevlar thread that balsa plane builders use to add lightweight reinforment. You just put CA on it and it dries into an extremely strong band-aid. I used it to repair my x-cars tab.
Old 02-19-2003, 06:53 PM
Blitzer Sonic
Hobbico is sending a mew a new chassis.
Rear locking tab? Burnout XMODS 1 04-04-2005 12:16 PM
Broken rear tab dje7447 Bit Char-G / MicroSizers 2 01-07-2004 10:19 PM
Rear Wheel just broke off EMX XMODS Parts and Hop-Ups 6 11-28-2003 10:10 PM
Tuning Basics sperry XMODS Parts and Hop-Ups 12 11-19-2003 01:56 AM
I broke a rear wheel connecting rod the other day.. Rotary Freak XMODS 0 11-11-2003 08:49 PM
