09-10-2002, 09:02 PM
sLaNteD ViSiOnS
so ur running on nothin at all................>?
"Nobody is perfect until you fall in love with them."
- Me
OH YEAH, GO KILL A BIRD!
09-10-2002, 09:22 PM
www.d1gp.com
umm...kinda..yeah...no springs, no struts...it has a more...lets say rigid suspension now...but i always race on smooth surfaces so its perfect
09-10-2002, 09:28 PM
sLaNteD ViSiOnS
hmmmmm.............
i havent tried that yet mayb i should...........
- Me
09-10-2002, 09:29 PM
sLaNteD ViSiOnS
has n e 1 tried to put like mayb rubber sleeves or sumthin on the shaft instead of springs yet.....?
if so tell me how it is.....
- Me
09-11-2002, 06:11 PM
That's a good idea, like some fuel tubing or small rubber washers - nice hard ride but with some damping - someone needs to try this!
09-11-2002, 07:46 PM
sLaNteD ViSiOnS
i was thinkin more on the line of heat srink tubing and stuff its more flexible.....
- Me
09-11-2002, 08:15 PM
www.d1gp.com
thats a good idea..but im still trying to think/find a good material or object to use...
09-12-2002, 02:27 AM
Location: Australia, Esperance. Some Of the Best beaches in the world
What about a really soft foam that absorbs the shoks but inflates back just enough to get back to original?
Efficient use of Skill is gained with Time, although Efficient use of Time is sometimes not gained with Skill.
09-12-2002, 02:29 AM
BIT PIMP
In my opinion, I think anything rubbery or grippy like soft tubing, is going to make the steering worse. Unless you put some kind of a metal washer between it to make em smoother.
Just an opinion.
silla
10-04-2002, 04:47 PM
My Alter Ego Is Retarded
I tried to put springs on my bit and had the same problems with the stearing so here is what i did, i shaved the ribbing off of the underside of the stabilizer bar and put it on upsode down, then i shaved off equal amounts of material from each side untill i was happy with the handeling of my car
I like Pie
10-05-2002, 11:45 AM
Yeah...I took my suspension set off...and the car steering and handling was horrible...the stabisus kit is a must have upgrade.
10-15-2002, 06:51 PM
yellow fish forever!
it does not matter what kind of "suspension" you have, you just need to have something so it does not riding rock bottom all the time. Unless you have springs or a stablizer, your steering will be weaker and less responsive, and sometimes will get stuck going around corners and such.
also, i think that the qfm springs would make the front wheels slide more, resulting in wider, smoother turns. Payaso or anyone who has done this successfully: how do springs compare?
10-15-2002, 07:06 PM
BIT PIMP
The springs do make the turns a little wider, but I prefer it like this...
In my opinion, the spring mod is a must... especially if you use faster motors.. If you use the stabius, when one wheel goes up, it forces the other down, to where springs are fully independant.... I use the springs without the stabius... Springs are the way to go...
silla
10-20-2002, 08:25 PM
Ill choke slam you!!
did mod didnt work
i put springs on my zip, didnt work, because the springs are metal they interfere with the magnets, where can i get springs that wont do this???
10-20-2002, 08:39 PM
BIT PIMP
Re: did mod didnt work
Go to QFM... Their springs are treated....
silla
