01-12-2003, 10:13 PM
i am po
If you wanted to paint you bit, you have to remove the original color? what will happen if you dont? will it not look as good?
thx
01-12-2003, 10:27 PM
Mr. Goop
just get some gray spray primer/paint and paint the primer on first... (after you remove the stickers). after its been primed you should be good to go with any type of paint job.
01-13-2003, 12:54 AM
Mr. Goop
painting on the inside really only loooks good if the body is the thin plastic/lexan like the bigger r/c bodys. the thicker plastic looks good with paint on the outside, just remember to put a few coats of clear over the final paint job and it will look great!
at least thats my opinion..
01-13-2003, 02:17 AM
PLOOP!
has anyone actually painted with acryllics? just asking cause brushing this stuff on would be easier for me. i got mad brush skillz! heh heh
01-13-2003, 02:20 AM
Told ya.
Thin the acryllic first. I stink using a brush but if you gots mad skillz then by all means go ahead.
____________________
Meh.
01-13-2003, 10:21 AM
Garage Rocker
After you've clear coated with acrylic laquer, you can get the shine over the top by waiting at least a week for it to dry. Don't handle it during that time, as handling helps keep the paint soft. Wet sand it with some really fine grit sand paper, like 1500 or 2000 grit. Let the paper soak over night, so it's fully saturated, and flexible. Be really super careful around edges, and bumps sticking up. Avoid even hitting them with the sand paper if at all possible. I just folded the sandpaper into a small piece, and used the corner. Then went over it with some Rubbing Compound. I used some 3m stuff. Again be super careful around the edges, as rubbing compound is like a fine grade sandpaper. Then finish with a high grade polish/swirl remover, like Meguiers.
The dipping in Future might be an easier idea, but this is the way they do it on real cars, and I got really good results. If you paint a body with a brush, this is also how you level it out, and make it look more professional. If you really globbed the paint on, let it dry longer, like maybe even a month. Then use like 800 or a 1000 grit to level it out, and then proceed as above
Check out the pic in my sig of the Celica. The picture doesn't do it justice, because of the harsh lighting of the flash, but in natural lighting, it looks great.
Dave
