Old 01-12-2003, 12:42 PM
Minisizer Minisizer is offline
Unhappy Seperating gear and wheel from rear axle
How do I seperate that annoying gear and wheel from the rear axle? I am trying to do the fullsize wheelset and it isn't that easy.
Old 01-12-2003, 01:47 PM
jah_jrok jah_jrok is offline
I drank what?? (Socrates)
I used a 2 step procedure:
Step 1: Twist
Step 2: Pull
Repeat as needed
Old 01-12-2003, 03:49 PM
strider_mt2k
I recently did this so I could transplant my "good" "turbo" gear from the Zip Zaps rear it was attached to onto my shen so I could keep my wheels matched.
I used a pair of small needle nose pliers to hold the axle once I had pulled off one wheel.
The press-fit from the facotry will be shot now, so have some model glue or super glue handy to re-seat the wheels in the axles.
Make sure you hold the center of the axle, or close to it! If you rough up the axle where chassis holds it, it will perform poorly and wear out the chassis quickly.
I also set up the gear side first and let it dry so I could snap in the axle and adjust the wheel spacing right for minimum sway when I glued in the other wheel. The resulting rear looks great, and has a closer tolerance than when it was new.
I have to repeat here that the Zip Zaps Fast & Furious kit is a great value for the parts you get. I don't even care about the car bodies! The motors, rears and suspensions, not to mention the tires, all have some use for anyone looking to mod!
Old 01-12-2003, 04:21 PM
Ok, that is a little better description that my process
Full Rear Wheel Drive Snake Mod ZipZaps 14 06-23-2006 02:59 PM
Monster Hummer!!! Buzzbait Bit Char-G / MicroSizers 5 06-26-2003 07:22 AM
new and improved axle holder fix hogjowlz Bit Char-G / MicroSizers 1 03-04-2003 04:24 PM
Wheel mod on stock rear end slotsurfer Auldey (All) 2 01-13-2003 12:45 AM
