05-09-2003, 11:40 PM
Suspension plate tip
Since I found the stock suspension plate of the Mid too soft, I 've fabricated a couple of CF versions for myself and my friends. I realize not everybody has CF plates or the tools on hand to make CF plates themselves. Because I was too lazy to make one the other day, I discovered a way to make a better suspension plate for the Mid without cutting, grinding, drilling, etc. -- epoxy two stock suspension plates together! The result is a durable and "just right" plate.
05-13-2003, 02:16 PM
nomotorlimit@hotmail.com
Yup. did that as soon as I got my Kawada Mid Running. You can also use ZAP ca glue.
Here's the tip: If you have a broken Graphite H-plate from a mini Z, glue it on the bottom of the plate, lengthwise. Let dry and you got yourself a stiffer plate.
Endless possibilities with the ABC's
05-21-2003, 04:21 AM
Another thing you can do is have donut make you one!  That's what I did...
Racing is LIFE... Everything else is WAITING...
Micro Racers, visit:
07-04-2003, 08:35 AM
Thanx that really helped with my broken plate.
Do you feel the heat yet?
