Go Back   TinyRC.com > 1/24 and Smaller > Dynamite Rocket Racer > Dynamite Rocket Racer Parts and Hop-Ups
Old 01-03-2003, 12:19 PM
MicroRCEngineering MicroRCEngineering is offline
nomotorlimit@hotmail.com
How to make your DTM RR run like the ABC DTM
will soon post tips and tricks.
Endless possibilities with the ABC's
Old 01-03-2003, 02:54 PM
dtmracer dtmracer is offline
ill put in some info that i have tried on my drr. i dont know if you noticed that the drr oversteers one way and understeers the other way, but mine and my friends did. my and my friends car were both tweaked in the front end when we got them. we tried untweaking it by bending the chassis. but anyways like a week later the tire wear just corrected the tweak i guess cause it wasnt tweaked anymore. it still oversteered(right) one way and understeered(left) the other way. i thought it might be the diff. so i put a abc spur in because it has 12 diff balls instead of only 8 that are in the drr. also lube it up with losi diff lube, white for thrust, and clear for spur. my drr also was spinning out alot so i thought it needed a softer rear suspension. so this is what i did. i switched the thing that the t-plate mounts to around, so the longer leg goes toward the front of the car. i also took off the spring. i also gound off the rounded part of the t plate(see pic) o and lengthening the wheelbase also helps.
Old 01-03-2003, 03:00 PM
oops forgot to put pic of tplate
My New ABC DTM SP Cruizer ABC DTM Gallery 19 01-08-2003 07:00 PM
Abc Dtm Oman ABC DTM SP 4 08-25-2002 03:09 AM
RTR abc dtm sp? andrzejpw ABC DTM SP 28 08-22-2002 05:09 PM
abc dtm x4 nevwerg ABC DTM X4 12 07-21-2002 05:32 AM
Hollywood's ABC DTM X4 -Almost Ready! Chezedog ABC DTM X4 7 05-10-2002 11:20 AM
