08-12-2002, 11:48 PM
Well,
Tight lipped: You STILL won't tell me the mah's of your pack.
I didn't mention you or a pic of your pack because I don't want to piss off the moderator of the site for mentioning another site. BUT you should feel free to post a link in that thread, it is YOUR SITE you would be supplying a link to.
Tell you what I WILL do, I am going to post a modified version of that thread as an article on Tiny RC's site, I'll mention you, put in a link to your site and a pic of your pack.
Is that good for you?
09-23-2002, 03:52 PM
Micro RC Innovator
[quote]Originally posted by gertman
Neither can compare to a stock Mini Z. The only known way to increase speed is to get a lighter body. [/QUOte
cant a 4 cell spec2 beat a stock mini-z?
09-23-2002, 05:43 PM
Yes, you got me, since I made that statement along time ago, we have since found ways to increase the speed of an Epoch by adding more cells.
Sorry, I do not have a stock mini-Z to compare to my 4-cell, BUt I have a feeling it would be very close.
-Engineering Manager
01-29-2003, 08:49 PM
Gertman, excellent "how to" article! Please answer a couple of questions before I get started with constructing a 4-cell pack.
The 4th battery in the picture had a tab already spot-welded...
The batteries I'm working with don't come with a tab. It's unlikely I'm going to find that same material (it's unusually "bendable") in my local hardware store. Any ideas on what it is, e.g. tin? or where to get some?
Also, the stock battery pack in encased in shrink-wrap. However, in your article you didn't replace the shrink-wrap to cover the 4th cell. Is that because the heat necessary to shrink the wrapping will damage the battery?
Thanks in advance.
01-29-2003, 08:52 PM
You can use small guage wire or a piece of tin.
I did not re-shrink wrap the 4th cell because I didn't have any.
06-06-2003, 05:52 AM
I pitted my X-Speed Overland (slightly slower than a Mini-Z Racer with same motor) against my recently-acquired 4-batt Epoch tonight. It was indeed quite close, but the Overland was very slightly quicker both in top end and off the line. The Overland doesn't have any other speed related upgrades (not even bearings) and was using the stock pinion gear.
I also have a racer with external Eagle turbo and S-03 with 12T pinion, bearings and other tweaks. It's quite a bit faster than either the Overland or the Epoch, obviously.
I am however quite impressed with the little Epoch overall with the 4 batt mod. Nimble, a little prone to losing traction but pretty quick for the size. I wish Epoch had taken the same tweak-it approach that Kyosho took with the Mini-Z. Sadly, the limited parts and access to same makes it less attractive to people who want to get the most out of their micro.
bill
03-16-2009, 05:12 PM
Does anyone still sell the Epoch new?
03-16-2009, 09:42 PM
I only know of one place and that's right HERE at TinyRC's shop. But he only has a limitted supply of stuff left.
03-17-2009, 12:09 AM
We've actually got a bunch more stuff than what's listed, so if you don't see what you need, just open a Support Ticket - thanks!
04-09-2009, 05:02 PM
I have some cars available, only 1 is brand new in box. the rest BNIB's have sold already here is the link: http://tinyrc.com/forums/showthread.php?t=23962
08-31-2011, 09:56 AM
Helloooooooo
Just thought I would kick the dust off in here!
I guess most of the 1/43 guys switched over to Dnano's when they came out and I have one on the way, BUT I still have 3 Epochs that I dug out of the closet. I have been running them on my 3 lane routed 1/43 scale slot car track and enjoying them quite a bit. I am guessing some new batteries would help immensely, but what I am wondering right now is where to get replacement springs for the front suspension!?
12-17-2018, 09:53 PM
Epoch tuner wanted
Looking for someone to replace batts. or 4 cell mod on two spec 2 cars, can supply batts. if needed. I'm to old work on Tiny stuff any more, Ha Ha Thanks Rich.
