01-31-2003, 07:44 PM
6v battery=NOS!!
you can do the gears not the motors
01-31-2003, 11:20 PM
mwhahahahaha......
execellent......
02-01-2003, 01:14 AM
My Alter Ego Is Retarded
Hold on a sec, I put the turbo motor in my 2 cell clone and it fit just fine, I have not tried to put one in my bit yet.
I like Pie
02-01-2003, 06:41 AM
6v battery=NOS!!
the turbo won't fit in my microsizer
02-01-2003, 07:41 AM
Originally posted by fuzzy2cell
to answer your question, on battery lasts about 90 minutes of straight running
Was referring to a different pic, sorry for confusion
02-01-2003, 07:44 AM
If you have a bit/microsizer/shen or anything else like that, what speed did it hit?
I can't honestly tell you.
I still haven't seen a definative speed measuring technique.
What is the standardized, universally approved method of speed measurement?
02-01-2003, 07:47 AM
My shen, and Cyclona both handle the motors and rears.
The only clone that's burned me so far is Bensu Micromites, although it was good for parts, heheh
02-01-2003, 12:10 PM
da da dum da dum da da
what is the best way to measure speed other than with a treadmill 'cause i dont have one?
"Do you want a new Bit Char-G
WELL I DO TOO!!!!!!!!!!"-me
"i'll let you win, on one condition beat me"-me
racing down akina
02-01-2003, 12:44 PM
If you dont have a treadmill try this, its not as accurate but for our purposes it will work.
First get a buddy to help you, then measure out a 5 ft span.
Get your bit up to top speed before you cross the first line, as soon as you cross the first line have your helper start a timer, When you cross the other line have him stop it. Do as many runs as you can and average the times, this should improve the accuracy of the times.
Once you have the times averaged lets call that 2 seconds I will post the math so all you have to do is plug yoour times into the calculator using the following equations
devide 5 by your time, this will give you your feet per second
next take that answer and multiply it by 3600
then devide it by 5280 for your mph
Finally multiply that by 70 for your scale mph
5/2=2.5 feet per second
2.5*3600=9000 feet per hour
9000/5280=1.7 mph
1.7*70=119 scale mph
Hope that helps!
I like Pie
02-01-2003, 02:58 PM
thank you bates...it makes much sense now
02-01-2003, 03:43 PM
hehe, sometimes it's hard to keep my bit going in a straight line. it'll take a few runs to get it to get to the line. hehehe.
iLLuSionZ of FusIon
DA fusion
i need help with my car
www.g2ic.com
02-02-2003, 08:56 PM
That's all folks
Using the time/distance method, I measured my 2 cell Zip Zap (see Black Honda in signature) at 4.5 mph.
That's all folks!
02-02-2003, 10:20 PM
So far the fastest is 6.5 mph, can anyone beat that?
I like Pie
02-03-2003, 02:55 AM
Mr. Goop
hey fuzzy,
how did you attach that battery? it dosent look like it was soldered, and second if you got it at RS what was the part number?
thanks
02-03-2003, 06:47 AM
custom title
batesjm
thanks for posting the math
i knew it was something like that
if you guys time it over for example 10 feet, you would divide by 10 in the beginning and the rest would be the same.
current parts:
auto modellista
4.2 pro
perfection 200mah battery
Pullback wheel mod
Plantraco desktop rover for sale
email me at eman54@optonline.net if you want it
