Old 12-12-2003, 06:50 PM
FastRSX FastRSX is offline
How many batteries (or volts) were you using with the motor?
Sorry to hear the motor didn't work out. Well, maybe we can take it apart for parts. I really like the way it looks.
Old 12-12-2003, 06:54 PM
3series takumi's Avatar
3series takumi 3series takumi is offline
mini-eX-Driver
Send a message via ICQ to 3series takumi Send a message via AIM to 3series takumi Send a message via Yahoo to 3series takumi
miniz x-speed, pn-speey, pn s01 s02 s03, GPM Modified Speed and Torque Motor
try any of those?
soon to be
mini cooperS (bmw) mini-x
novak xxl receiver
lrp quantum micro esc
hpi micro mod
5 2/3a zapped cells
novak 10v 4700u power cap
xmod suspension
xmod wheels and tire upgrade
Old 12-12-2003, 07:00 PM
geofroley's Avatar
geofroley geofroley is offline
R34 Skyline is God
Send a message via AIM to geofroley
Where do I get these?
My Bit: Phast motor (Orange)
Soon to come: (Undecided) Custom Rims
Old 12-12-2003, 07:02 PM
mini-eX-Driver
at places that sell miniz's
i got to tokyotekki out her in california
soon to be
novak xxl receiver
hpi micro mod
5 2/3a zapped cells
xmod suspension
Old 12-12-2003, 07:11 PM
The Torque Motor was a little better then the stage 2 motors. Had more torque with about the same top speed. Ran this set-up with red or yellow gears on a awd.
The best motor I've found is a SpinBrush. The com was polished, advance time, oiled, adjusted brush tension, and a drop of com juice. It has so much torque down low that the soft treaded tires sill doesn’t hook up. Then after being run in it smokes the 30k x-mod motors.
I must state that this is all done on a 6-cell car.
Old 12-12-2003, 08:43 PM
neurokinetik's Avatar
Mad Scientist
Guys, forget about these 130 motors...
to the big block:
http://www.tinyrc.com/forums/showthr...threadid=16020
Old 12-13-2003, 06:21 AM
geofroley's Avatar
R34 Skyline is God
But those are 180's I looked up Tower Hobbies and found some Mini-Z motors that might be fast. I'll get the link up later.
Old 12-13-2003, 06:30 AM
geofroley's Avatar
R34 Skyline is God
Actually, those motors look like their fast. . . but a 180 motor wouldn't fit in my RSX
Old 12-13-2003, 01:28 PM
Mad Scientist
Time for a body conversion and long wheelbase. Seriously. The difference is that big.
Anyway, I found out why the the Plasma Dash performed so much like my 25 turn motor... It's actually a 27 turn motor.
Armature itself is much different than what I have been seeing in all my other 130 motors though. Take a look (Tamiya motor is the top one):
Look familiar? It should. It looks almost identical to the armatures that I see in NML motors. Take not of the "fat boy" commutator, which is of a much better quality than any other motors I have disassembled so far. Time to get winding and see what I can come up with.
Old 12-13-2003, 01:40 PM
mini-eX-Driver
i am not sure what makes those fat coms better, but they work great compared to a regular motor. it is the same size com used in 180class motors
soon to be
novak xxl receiver
hpi micro mod
5 2/3a zapped cells
xmod suspension
Old 12-13-2003, 01:43 PM
Mad Scientist
I can tell you that there are two things better about them...
1. They are more true than the other ones. Less brush wear and more consistent performance.
2. The gap between adjacent contacts is smaller, leading to less arcing and overall better performance.
Old 12-25-2003, 08:15 PM
geofroley's Avatar
R34 Skyline is God
That 50,000 RPM motor looks cool.
Old 01-13-2004, 12:28 PM
cdog4w's Avatar
cdog4w cdog4w is offline
newbmaster
I've heard all sorts of motors mentioned in this thread, but no mention of the mini-zracer.com motors designed for the mini-z. Has anyone tried those? (maybe in another car like the mini-z or mini-x if not the xmod) I know one of them (Z-130-S-BB) comes with a ball bearing can, but is a bit expensive. For those without motor knowledge, would this be a good way to get custom performance if you have the $$?
My rides:
Old 01-13-2004, 05:29 PM
geofroley's Avatar
R34 Skyline is God
I'm using a PN Speedy and this things screams. Sucks out battery life though.
Old 01-13-2004, 05:39 PM
cdog4w's Avatar
newbmaster
Ah cool. Takumi recommends that as well. And hes not just the hair club president, hes a member too. (unless his sig lies
I don't have enough space to run inside anyway, so might as well go for some nice speed when I take it outside.
Takumi, do you still have your PN-Speedy hookup with the bushings to keep 4WD or did you try out the heatshrink tubing joint? Also, when you did the xmod wheel mod, you drilled out the hole, did you have to slot a groove for the mini-x wheel pin and then screw it on with the normal mini-x lug nut? (I know you're using the xmod universal something or other now so you use their D system)
EDIT: Forgot to say thanks...
Thanks!
My rides:
Tamiya 4WD motors... Railside270 XMODS Parts and Hop-Ups 10 12-25-2003 10:36 PM
mini-z or tamiya motors rob2fastx XMODS Parts and Hop-Ups 25 11-16-2003 03:45 PM
mini-z's and tamiya motors will they work rob2fastx XMODS 8 11-07-2003 08:50 PM
Tamiya motors? mbartell XMODS 0 10-10-2003 02:53 PM
tamiya motors rule!! MTL Auldey Parts and Hop-Ups 21 09-21-2003 06:55 PM
