03-12-2003, 01:03 AM
Poor Student
next again
Fight Crime <--> Shoot Back
03-12-2003, 01:04 AM
Poor Student
possible batt location
03-12-2003, 01:13 AM
Poor Student
Sorry for the poor pic quality. I'll take more with better lighting later if anybody needs clarification
03-12-2003, 05:49 PM
Blitzer Sonic
Whoaaaaaaaaaaaaaaaaaaaaaaaaaaa!!!!!!!!!!!!!!!!!!!! !!!!!!!
03-12-2003, 06:22 PM
How can I get the body back on?
03-12-2003, 06:29 PM
Poor Student
you cant... thats one of the probs. You could make a body adapter from thin aluminum to make the chassis fit a zip body.
03-12-2003, 07:28 PM
<(- -)> <- Yoda
WOW, that's one crazy mod...
wooo hooo!
03-12-2003, 10:51 PM
Blitzer Sonic
Do you know the gear ratio? Divide the number of teeth on the axle by the number of teeth on the pinion gear.
03-13-2003, 12:23 AM
Poor Student
3.83:1
03-14-2003, 01:06 AM
Poor Student
So, xatu have you tried this yet? You seemed interested.
03-14-2003, 10:57 AM
they say im slooooow eh?
Haven't tried it yet... But I will! It will be another addition onto project Frankenbit.... A shen that will be brought back to life
Does it spin out more often? And what are the downsides to this mod?
03-14-2003, 10:59 AM
Oh yes, and technically speaking.... Wouldn't you need to reverse the motor wires to make it go forward when you press forward? Or do you just leave the wires alone, and use reverse as forward, and forward as reverse?
03-14-2003, 01:36 PM
Poor Student
Yeah, you should switch the wires. I just used reverse, but I'm gonna switch the wires. Read my original post and the ones after, i answer all your questions in those.
03-15-2003, 11:11 AM
Poor Student
Its very easy to move the axle back to the normal location without hurting anything, so this mod is very easilly reversed. I cannot really think of many downsides other than it spins out a whole bunch. Again, more weight on the rear will cure that and make it handle like normal. You cannot get a bit body on after this mod, but i have yet to try a zip body... that may be the key. By not using the idler gear, you increase efficiency and reduce noise tenfold. The gear ratio is faster, so you will need a torquier motor or multiple cells. The gear ratio is 3.83 to 1 with the stock ms axle and 6 tooth pinion. I really wanna see other's takes on this.
03-26-2003, 10:15 AM
thats interesting. i bet you go through a lot of pinion gears.
