Go Back   TinyRC.com > Tracks
Old 09-03-2002, 11:51 PM
MattM MattM is offline
Sitting here on my couch i just discovered a pretty good surface - my couch - the fabric on it is MicroFiber which kinda looks like suede - its super grippy - the BCG seems to work pretty well on it - not sure how you'd make a track surface out of it but just putting in my 2 cents...
/mcm
Old 09-07-2002, 03:43 PM
1coolskyline 1coolskyline is offline
Send a message via AIM to 1coolskyline
Like i said my goal is not to make a track where there is no danger of slipping thats whats fun and challenging about racing. Finding that perfect setup. I think i am going with a particle board setup. I have not decided about the paint yet. Has anyone tried bigger rc tire compound yet? I have a bottle of it and might give it a shot one of these days. lata
where ever you go there you are!
Old 09-07-2002, 08:31 PM
killboy's Avatar
killboy killboy is offline
Hello all. I'd like to join in this discussion if ya don't mind.
I'm in the process of building an elaborate, elevated, 8x12' track on the cheap.
I'm getting 4 SOLID (box-steel framed) tables from where I work for free. (scrapped/replaced with upgraded manufacturing equipment) They are designed to seat 4x6' sections of 1 inch thick planks flush.
In my search for a surface, I also have decided on fiber board. It can be picked up at Lowe's here for $11 per 4x8 sheet at 5/8" thickness.
For my "Town" section, which will consume about 1/3 of the table, I will be using green/brown felt as grass/yards. There will be no barriers so one can drive off the streets and through the yards with a speed penalty if they so desire. (can you say fuzzy axels?) The slow-down caused by the felt will encourage drivers to stay on the streets I think. I have picked up some trees at a hobby store for $5, and a set of 3 pre-painted ceramic houses which include 17 decorative pieces (people, signs, wells) from Wal-Mart in the seasonal section for $17. They are internally lighted and intended to be used as a Thanksgiving town scene, so I'm going with an "Autumn" look. (browns)
The streets of the Town section will be lit by street lights - I am using string Christmas lights mounted on floral arrangement sticks. (Green sticks with stiff wiring around the top to arrange flowers - sold in bulk for next to nothing) I also found a couple of LED mini traffic lights on posts in the Seasonal section of Wal-Mart for $4. They even cycle in synch. (one green, the other red, vice versa with yellow in between)
My "Racetrack" section will feature a Dragstrip all the way down the side of the table, which will have removable walls so it can be used as a connector for the town and race sections. A large, high-speed square will go around the outer edge of the Race section, with banked turns. (poster board) Infield of this "Super Speedway" will be a large road course with removable walls so it can be connected to the Super Speedway, which can be connected to the Drag Strip, which can be connected to the Town.
I am using black "Tube Lights" for the track sidewalls on the infield. These tubes have lights inside them that light up orange for halloween purposes, but the tubes appear opaque black when turned off. They come with brackets for clamping them to flat surfaces, and they are $8 for 18 feet.
I will also cut small rectangles from the grid of an old Lite-Brite and fill all the holes with X-mas lights to create 4 "Stadium Light" clusters around the sides of the Super Speedway.
All this lighting, along with the Tube Lights should allow us to run "Night Races" using only the lighting of the table and the cars.
Finally I plan to create a street of moving traffic on one of the longer Town streets by using fishing string to pull matchbox cars down the road along a loop that will go underneath the table, and be powered by a simple, low-speed project motor. The concept is hard to explain, but basically there will be 2 holes in the surface, and the string will carry the cars up through the first hole, drag them down the street, then they will fall down through the second hole to be carried across underneath the table and repeat. I plan to have 2 lanes of traffic, one slightly faster than the other so the traffic pattern will vary. Small, shallow grooves for the fishing string to travel in should keep from upsetting the racers.
This traffic will create 3 types of driving hazards. Crossing their street will take timing. Driving with traffic, and driving against traffic (wrong way) should be interesing as well.
I may look into the chalkboard paint for the surface, or I may try black primer. (good coverage, cheap) Also picked up a 4 inch wide, 35 inch long strip of "Brick Road" material, which is sort of rubbery, for $5. I plan to use it in some of the alleys in the Town section. There will be slick sections and rough sections to hopefully equalize all types of car setups. Maybe a jump or 2 also.
So there are some ideas to play with I guess. I still have many known and unknown obstacles to encounter, but you guys have helped me out with several snags, so I wanted to give something back
Layda,
Darryl
Old 09-07-2002, 09:28 PM
hey its all in what you want. I am going for racing action not scale modeling but thats cool too. I just want to build a track that i can change layout anyway i want. Fiberboard i am not sure what that is or what we call it around these parts.lol My design uses a sheet of particle board. I dont think i am gonna do a four by eight but rather a three by six i dont have a huge room to use and i want to keep it compact i mean our cars are small.lol Well i gotta run peace all good ideas.lata
Old 09-09-2002, 01:29 AM
payaso payaso is offline
BIT PIMP
WOW
Wow killboy, Talk about giving something back. I can't wait to see some pics or maybe even a movie. It sounds like this isn't your first rodeo....LOL
silla
Old 09-09-2002, 04:00 AM
killboy's Avatar
Thnx payaso. Photography and Videography are a couple of my other hobbies, along with video editing, (see website) so I hope to have some jammin Bit Char-G video put to music one day in the near future.
I also have a color spy-cam that I intend to mount on a Bit do a full lap on-board chasing another bit. (it'll be a while)
Layda,
Darryl
Old 09-10-2002, 03:44 AM
killboy's Avatar
Had a couple more ideas for track surface material.
Asphault Sealant - Cheap; Good coverage; tacky/sticky; a bit hard to work with.
Fabric - Use the canvas type, like work uniforms are made out of. I tested my bit out on a large spread of this type of material and it was perfect. I'm going to cover the surface of our track with black or grey.
For those keeping score, others have also listed:
Chalk Board Paint
Black Primer
Styrofoam
Fiber Board (raw)
Layda,
Darryl
Old 09-16-2002, 03:31 PM
killboy's Avatar
Looking good, booster. Just a suggestion, but you might look into covering the cork with felt. There is a place in town here that sells it in all sorts of colors at 7 sheets for a dollar. Each sheet is 12x18". You may not need barriers then, as the felt slows the cars down so if anyone drives across them they will be penalized.
Layda,
Darryl
Old 09-16-2002, 03:36 PM
slugbugg slugbugg is offline
I KNOW NOTHING!!!
another idea
I was just thinking about track details and remembered that some of those old (I havnt seen the new ones) print shop type programs have craft projects that allow you to make various buildings and stuff that could be scaled to almost any size and printed with an endless variety of details.
paper buildings = cheap + custom + safe for the bits and it might be cool to watch a bit crash into/through a building.
just a simple thought from a simple mind.
Old 09-17-2002, 02:29 AM
killboy's Avatar
Along those same lines, slugbugg, I had considered making a city of tall buildings using tall skinny milk cartons and print outs of pictures of skyscrapers glued to the sides of them.
I ended up using ceramic houses. I may still one day to a city...
Layda,
Darryl
Old 09-27-2002, 09:08 AM
lowerdfool's Avatar
lowerdfool lowerdfool is offline
Microrcfool
Send a message via AIM to lowerdfool Send a message via Yahoo to lowerdfool
Chalk Board Paint
Black Primer
Styrofoam
Fiber Board (raw)
I'm using rubberized undercoating. I sprayed it out last night and it was dry this morning. It's got a pavement type look and is quite tacky. It doesn't lump up very much either. I'll try to get a close up pic when I'm finished.
"What's a low fool?" lol
Old 09-27-2002, 09:35 AM
killboy's Avatar
Is that the stuff that goes up under fenders on cars? (full size cars, not RC cars, toy cars, model cars, or transformers (toy transformers, not electrical transformers))
Ok I'm going to bed now.
Layda,
Darryl
Old 09-27-2002, 10:02 AM
lowerdfool's Avatar
Microrcfool
Yes. It doesn't build up like the stuff they use from the factory though. it only layed out about .5 - 1mm compared to factory car oem that's like 1/8" I bought it at meijers but walmart or any store like that should carry it.
Old 09-29-2002, 02:18 PM
I just got a sheet of 4x8 5/8 particle board at my local lowes today painted it with chalk board paint. Took two cans I didnt get a chance to try it out yet it looks nice real nice pavement like texture i cant wait to give it a shot. next i am working on barriers and walls. I will take pics of my track as i progress peace.
Old 09-29-2002, 03:04 PM
Angry Ice
Hmmm, Im making my track out of Carboard, and painting it. I sprayed black epoxy and then will cover it with paper if its too sticky, or leave as is. Its still drying, but I think it shall be nice and smooth. I also have a sweet ramp.
My New track and a pic of my work area zydio ZipZaps Gallery 15 01-12-2005 04:17 PM
Show Me YOUR Tracks (and videos) Please! BoostedLoser Tracks 51 01-30-2003 04:01 PM
New Track Racer9 Tracks 1 12-16-2002 08:57 PM
