01-23-2003, 05:28 PM
Bit Obessed...
so would gluing a pen tip to my bit make it go faster? the bigger it is the faster right, since it'll act as a rocket thingy.........riiiiiiight?????
01-23-2003, 05:32 PM
Corolla Power!
nah....but alot of people mention bottle rockets on bits....DON'T DO IT!!! I tried it on a "shell" (car with nothin in it)...didn't move at all, and just blew up.
01-23-2003, 05:55 PM
Back to the original question.
Just take some staples, cut them to the right size and stuff them in the grill.
This is how mine looked before i got an R-spec motor. I cant keep it in now....keep running into stuff.
01-23-2003, 06:33 PM
www.d1gp.com
kool picture
01-23-2003, 09:24 PM
Just to clarify...wheels are not rice.
01-23-2003, 10:37 PM
yeah yeah really.
i saw this dude with this fat kit, big ħ§ spoiler
the works.
he pops the hood on his civic
stock.....
same here the above was intended as a joke
A man who desired nothing is invincible.
01-23-2003, 10:40 PM
how many people are going to see that /\ ^ /\ and wait for a picture to load lol
***  AMC Veteran  ***
-- ^-_-^
01-23-2003, 10:48 PM
jei$, whast wrong with looks and no power to back it up. Speed gets you tickets anyways. If your car looks good it gets attention, if its some ass car with a big block in it, it will get you attention........from the cops. I would way rather have the first of the two.
01-23-2003, 11:53 PM
hehehe
***  AMC Veteran  ***
-- ^-_-^
01-24-2003, 12:04 AM
LOL
***  AMC Veteran  ***
-- ^-_-^
01-24-2003, 02:24 AM
PLOOP!
everything...
ever try driving around in a super riced out car? you'll have cops all over your ass like mike tyson at a beauty pagent...
id rather have the ****tiest looking car with the best performance ever, rather than any wannabe... that just makes you look like a poser... people might as well shave their heads, tatoo 3 x's on their neck, buy an rx7 with the biggest stero system in the back, and race it with ja rule.... and when you win you can scream "welcome to the zander zone!!!"
01-24-2003, 03:06 AM
LOL at all the anti rice comments
No nothing is wrong with wheels untill they get so big they cause the car to ride so high up it looks like it's about to go off road.
Or when you get wheels that are to big and heavy they actually slow your car down. Even if you get bigger wheels that are lighter than smaller stock wheels they can still slow you down due to the increase in rotational mass.
"Actually, there is a relationship between rotating and static weight. For the purposes of a car,
a=T(2/md+d/2I)
a = acceleration
T = torque driving the wheel
m = mass the wheel must "tow" from the center of rotation (COR)
d = diameter of tire
I = polar moment of inertia of wheel/tire combination
This was derived from first principles. The first term comes from F=ma where F = T/(d/2) --> d/2 is the moment arm at which the force from the ground on the tire acts. The 2nd term comes from a = alpha*(d/2) where alpha is angular acceleration. T=alpha*I.
(I) is not easy to calculate for complicated shapes like wheels... it is usually measured. The general form is (I) = sum (mi*di^2). (mi) is the "lump" of mass at a distance (di) from the COR. Break up your wheel into a zillion parts, measure the distance from the COR to each part, sum them all up using the above equation, and you get (I) :-). As an example, let's take a simple shape: for a uniformly distributed disk, (I) = md^2/8. Plugging into the above equation for (a), we get:
a=T(2/md+4/m_wd) where m_w is the weight of the wheel. Thus, we can see that for a uniformly distributed disk (like a hockey puck), the importance of rotational weight is 2x that of static weight (if the weight was static, it would contribute to the first term with the "2" factor, if it was rotational, it would contribute to the 2nd term with the "4" factor). However, a typical wheel/tire combination has most of it's weight at the outer edges, which increases (I). Thus, rotational weight is more than 2x the equivalent static weight.... probably near 3x or more (for really heavy tires with light wheels).
Wheels with a larger moment of inertia (I) require more torque to _accelerate_ at the same rate as a wheel with a smaller I. For a given horsepower output, both wheels will eventually reach the same terminal velocity, but the wheel with the larger I will take longer to reach it. It is possible for a heavier wheel to accelerate at a faster rate than a lighter wheel for a given torque. As an example, let's say we have 2 identical 15" wheels. Now let's add 1 lb to wheel #1 at the very edge of the wheel, and 2 lbs to wheel #2 near the center of the wheel. Even though wheel #2 is heavier, it has a smaller polar moment of inertia (I) and thus will accelerate at a faster rate for a given torque than wheel #1.
You can, of course, calculate the acceleration, then work your way backwards and simply define an "effective mass" as the proportionality constant between F and a. In this case you'd arrive at
M_effective = (M + 4I/d^2)
However, such a definition is neither physical, nor possibly even useful. (I) is not easy to calculate for complicated shapes like wheels so that, eventually, you'll have to take a guess at (I), like..3x.
These are not things worth memorizing. However, you do need to know that and object with its mass far from the center has a greater moment of inertia than another object (of the same mass) with its mass near the center."
01-24-2003, 08:39 AM
Clones Are Good
So much for sarcasm.
01-24-2003, 11:35 AM
lol
