Old 03-20-2004, 12:29 PM
newbitowner's Avatar
newbitowner newbitowner is offline
metal nuts with nylon threads would be nice!
G35 rolling chassis
H2 rolling chassis
Cobra,rolling chassis
red Supra SOLD
65' Mustang...SOLD
Corvette... SOLD
WRX...SOLD
blue Civic...SOLD
Old 03-20-2004, 01:11 PM
TypeZer0's Avatar
TypeZer0 TypeZer0 is offline
0reZepyT
i like to see wheels and tires that are plastic, resemble brand name aftermarket wheels from enkei and other companies, and are wider. they should have the same offset so that the extra width would protrude outwards. i like to see treaded tires that have sharply cut grooves in it, not the rounded groove edges of the treaded tires from the RS tire upgrade kit. (hope you know what i mean, if not i'll throw up a pic later)
Friends (Joey's Bag)
Rachel: Exactly! Unisex!
Old 03-21-2004, 03:47 PM
Zero-Man
Nylon locknuts are availble for the Mini-Z and are the perfect fit for the X-Mod. Check the sister site, mini-zracer.com
Any 2mm locknut will work. Also check the FAQ section, this has been discussed in depth somwhere in there.
Old 03-23-2004, 04:44 PM
aperson's Avatar
aperson aperson is offline
I'm not a pyro, really.
TypeZer0, why plastic tires?
has anyone tried to use a CD as a wheel? we used to use them for that for some project in wood working.
NEVER UNDERESTIMATE THE POWER
Old 03-23-2004, 09:20 PM
neurokinetik's Avatar
Mad Scientist
I'm a big fan of the 15 degree GPM sport edge radials for the Mini-Z. They work well on the carpet that I run on. Once it actually gets warm enough to run outside, I'll have to find the preferred setup for asphalt.
Old 04-06-2004, 11:22 AM
micro kid's Avatar
micro kid micro kid is offline
Do you getto dremel?
id like to see somthing like a micky thompson sportsman tire in a soft compound they look like the duratrax street trac tires
racing on pavement is for wussies.
Old 04-06-2004, 05:56 PM
TypeZer0's Avatar
0reZepyT
actually, i meant plastic wheels and rubber tires. didn't really think when i was typing
Old 04-07-2004, 02:31 AM
spinitsidewayz!'s Avatar
spinitsidewayz! spinitsidewayz! is offline
boro dori style RC
i want some tires that are nice and grippy but dont crumble off like the xmod ones. i have a pair that i stuck on my rear and the thread is gone after 2 days of drifting in my garage...
r34 - rwd
r34 - awd
dd4 - fwd
Old 04-07-2004, 05:26 PM
aperson's Avatar
IDK if its possible but softer rubber on the outside and harder on the inside. that way the tires wouldnt come off as easily like the totally soft ones do. how about paddle tires?
Old 04-10-2004, 10:29 PM
Tbird Man Tbird Man is offline
one word, foams, better foams than the RS ones. or perhaps silicone. and how about a modified ball diff to fix the annoying slip from the washers not locking to the hubs? possible? I have ideas. and how difficult would it be to make alu. outer shafts and universals?
Nissan Skyline GTR v-spec
AWD
suspension upgrade (soft rear med front)
180 size motor, custom made heatsink
GPM alu front knuckles, shocks and center bering holders.
more to come...
Old 04-14-2004, 11:53 AM
aperson's Avatar
maybe they could replace the rear with aluminum universals too. no more broken cup joints. maybe they could sell them with rubber boots over them?
Old 06-14-2004, 02:32 PM
fastflyinclipse fastflyinclipse is offline
its just a thought but if you guys could make like a tire for like goin in the dirt and make sumthin that fits around the holes where dirt could get in (or just b cheap like i would and stuff cardboard up there) but yeah its not much to work off of but i think its possible.
YAY MY FIRST POST
why must we try to fly when all we will do is die?
Old 06-23-2004, 02:54 PM
itsme
Knobby tires! XP
Old 06-28-2004, 07:22 PM
viperdout's Avatar
It's Really Fast!
Originally posted by Akira36
I almost forgot, another Idea I've been pondering a tire purpose made to adjust to the camber-happy characteristics of the rear suspension, high profile on the outside, low profile on the inside..
I attached a crappy mspaint diagram to give you an idea of what I'm talking about.
The problem with that design is it will not correct the problem, and instead make it worse. If you reverse it, It will make it a whole lot better.
Project Bad Brushless:
Just say no to giant sigs.
Old 07-01-2004, 11:12 AM
xXSoulsRepentXx xXSoulsRepentXx is offline
Something like this I run these wider and higher profile tires for drag. These also have a tread.
You know nothing. Hell is only a word, reality is much much worse.
Day's goodies and Cheap Foam Tires Jazz32 XMODS Parts and Hop-Ups 5 07-20-2006 11:01 AM
Contest: TinyRC.com XMODS Shop Banner tinyrc XMODS 101 03-25-2006 11:10 PM
XMODS Foam Tires Spongebob Dynamite Rocket Racer Parts and Hop-Ups 1 02-07-2004 05:08 PM
Xmods Announcement cj1267 XMODS 2 10-16-2003 04:34 PM
