02-06-2004, 05:17 PM
Happiness is a warm gun..
How long do your batts last?
02-06-2004, 06:15 PM
It's Really Fast!
This is my 200th post
My aaas last about 2 hours. The batts were low in that shot.
02-06-2004, 07:43 PM
2hrs?!
G35 rolling chassis
H2 rolling chassis
Cobra,rolling chassis
red Supra SOLD
65' Mustang...SOLD
Corvette... SOLD
WRX...SOLD
blue Civic...SOLD
02-06-2004, 08:18 PM
TinyRC XModder
Originally posted by newbitowner
2hrs?!
Yeah, he probably means that at the end of 2 hours it won't even move.
For Sale:
|XMod :: Black Supra|
-4/5/6 Cell Mod
-Rayovac IC-3's
-Body kit
-Wheel & Tire upgrade
-All Wheel Drive Kit
-Ball Bearing Upgrade
[url]
02-06-2004, 08:29 PM
It's Really Fast!
No, the wheels move, it just has no more torque after that. Are the Rayovacs any good? Also, how do you get a pinion gear off of a motor? I have a sb motor, but I can't get the gear off of the other motor. I have a Stage 2 Drag in it right now, so I can destroy the stock motor.
02-06-2004, 09:53 PM
TinyRC XModder
Yeah, Rayovac IC3's are awsome, you'll get a longer run time, with more tourqe, and they charge in 15 minutes.
You need a pinon puller to get a pinion off an armature without damaging either. If you get one, make sure it'll work with XMods' shaft diameter.
For Sale:
-4/5/6 Cell Mod
-Rayovac IC-3's
-Body kit
[url]
02-07-2004, 08:58 AM
It's Really Fast!
How do I do it with a vice and a plenthora of pliers?
02-07-2004, 02:30 PM
Mad Scientist
If you do it that way, don't expect to have a usable gear or a usable motor. Just get a pinion puller and save yourself the grief.
02-07-2004, 04:04 PM
It's Really Fast!
I just got new batts (couldn't find IC3s, just found aas) and I tore not only a tire, but somehow ripped out a wire to the batt pack. I'm at my dad's house, so there's no iron w/ me. I'm gonna go up to the blue motor, because this has too much torque (did I just write that?). On an unfinished floor, I do perfect drifts, but on finished hardwood, it's just donuts at full speed. Oh well, at least I made plates to match my dad's 1:1 RSX (it's silver also). I almost forgot, why did RS make the RSX w/ no sunroof? All RSX's here are sold with one. That bugs me. Also, it rides lower than it should compared to the real thing, but I'm not complaining. Later.
Edit: My X is losing range! I had to resolder the wire to the metal thing. Now bad range, what should I do?
02-07-2004, 11:22 PM
--PCB smoker--
Still running those 9v batts??
You possibly could have fried a resistor in the receiver on the car.
Or a short to ground on the antenna or short to positive I should say.
go here for some more insite on this........
http://pub238.ezboard.com/fxmodrcfrm...icID=324.topic
02-08-2004, 09:20 AM
It's Really Fast!
Yeah, but I've only driven it with it twice, and it started losing range when I was driving with 6 cells, not the 9 volt.
02-08-2004, 08:59 PM
--PCB smoker--
I have seen some peoples range decrease with the six cell, because.....
A. You fried the L1 or something resistor.
B. You have the wire(black) one that goes to the antenna crossing some other wires like the ones for the 2 other batteries and it is causing interferance.
My friend had to move his antenna up front cause it would go about 10+ and start to sputter.
02-09-2004, 02:06 PM
It's Really Fast!
well, the resistor isn't fried, and the wires aren't crossed. Anyway, I'm gonna replace them.
02-10-2004, 01:43 AM
Neuro why is this working so well? And still working at all?
02-12-2004, 07:46 PM
It's Really Fast!
Well, now the resistor's fried. Somehow, the wire musta touched a terminal. I was fixing the 6 cell, and I smell burning popcorn. First, I wlked over to the soldering iron, but nothing. I look back, and there's anice large curl of smoke pouring outta the plastic cover surrounding the crystal. Oh well, anyone have an extra front board? BTW, I live to work on anything.
