Old 01-20-2004, 04:22 PM
I Shall Return!
yea thanks that what i was figuring, i plan to take off this motor for now until i can get that fet mod dont, and possibly get a c-f chassis. whats motors would you recomend for me to put in my xmod, like i said i want tiring spinning torque as well as 20 mph+ top speed. ill prolly go down to my lhs this friday so i wanna know what motors to look for.
Old 01-20-2004, 05:24 PM
neurokinetik's Avatar
Mad Scientist
I haven't found an off-the-shelf motor that will give you good torque and that kind of top end. (I don't consider NML an "off-the-shelf" motor) Maybe a PN Racing S03, but again, that requires FETs. None of the available 180s are that fast without wind reduction or a complete rewind.
Old 01-20-2004, 05:27 PM
I Shall Return!
so say i bought a 180can team orion stock motor, and took off about 15 winds, what kind of performance could i expect?
- what kind of performance does the s03 give,
- how much dose it cost?
thnx again
Old 01-21-2004, 04:24 PM
I Shall Return!
hey neuro for a motor, i was thinkig along the lines of PN s03 motor or the Mini-ZRacer.com Super High Performance BB Motor Z-130-S-BB, please dont consider this a noob question, more so as an opinion, in your opinion which gives beter torque and power? also which is compadable with a 6cell upgrade
please note i will be purchasing new fets to upgrade as well...
Old 01-21-2004, 05:44 PM
Mad Scientist
The S03 is a favorite of the Mini-z guys, and for good reason. My own experiments have pointed me pretty much to the same thing. 35-39 turns, with thin Neo magnets. The Mini-z guys all require FET upgrades to run it, I think it's an iffy proposition in a stock XMod. I bet a double stack of the stock FETs could handle it fine, though. Just don't put a big pinion on it. 9 tooth max.
I don't know any specs on that particular Mini-Zracer.com motor. I don't recommend the Z-130-A-BB for XMods though. It was downright slow in these cars.
Old 01-21-2004, 08:39 PM
I Shall Return!
lol i know this sounds insane, but whats if i was to put my 12t pininon that i have? obviously the current draw would be through the roof but im pretty sure ill be getting some powerful fets ne wayz, o yea with 12T how badly would my torque suffer? i know this is all farfetch, but i want to beable to spin tires, as well as have a 25 mph top speed on stock batts
o yea im very much interested in your speed checker, where did you buy it from i saw one for 25 bux at a site that sells the s03 for around 28 bux
Old 01-22-2004, 09:36 PM
I Shall Return!
hmmm
Old 01-28-2004, 09:38 PM
NOS man's Avatar
NOS man NOS man is offline
SHYMERLOO!!!!
Send a message via AIM to NOS man
i know i asked this a whole bunch of tymes but HOW DO U GET THE FREAKIN PINION OFF?????!?!???!
What IM rUnnin
white toyota supra with:
All Wheel Drive
ball bearing upgrade
light set
stage 2 motor upgrade(blue)
nimh cell upgrade.
ENS (electric NOS simulation)
smoke exaust
fire exaust(optional)
!!!!!!!!SCREAMS!!!!!!!
Old 01-29-2004, 03:30 PM
Yell03SpecV Yell03SpecV is offline
pinion puller. end of story.
2003 RSX
S2 SB Hybrid, 11t, minus 10 winds, timing advanced 18 degrees
14G Wiring (craziness)
AWD
Hard Coils Front
Soft/Hard coils rear
Custom aluminum front upper deck
wheel+tire upgrade, currently soft tread rear, soft slicks front
Lightened body
Lightened chassis
Body Kit (not in use)
Old 01-29-2004, 04:47 PM
NOS man's Avatar
SHYMERLOO!!!!
besides dat..... i only got like $2 left.... allowance next month.... sux dont it...
What IM rUnnin
All Wheel Drive
light set
nimh cell upgrade.
smoke exaust
Old 01-29-2004, 06:39 PM
I Shall Return!
u can make a pinion puller
take like 10 soda cans, and cut away the aluminum, glue all the sheets together and bend in into a giant "U" then use a scissor or drill (with small bit) and make a slit on one of the "U's" arms (for the motor) and then put a tiny screw on the other arm of the U, put a motor in and tire black tape arount it to keep its shape, then use it like a pinion puller
or an easier appreoach would be to take the motor in question, wrap with many layers of Al, then take a lighter and hold it their for like 15 min... the Al will keep your motor safe... btw PLEASE USE PLIARS TO HOLD AND REMOVE THE PINION... i cant stress this enough!
Old 01-29-2004, 07:18 PM
TypeZer0's Avatar
TypeZer0 TypeZer0 is offline
0reZepyT
aluminum is gonna conduct the heat rather than shield it. that's why they use it to cool processors.
Friends (Joey's Bag)
Rachel: Exactly! Unisex!
Old 01-30-2004, 04:32 PM
I Shall Return!
yea but it works, put AL pver paper, and put a flame to the AL... the paper wont light because the AL blocks the heat, im not screwin with you, try it
Project VIPER (DEAD) New project S12Driver XMODS Mods and Projects 3 04-08-2008 02:44 AM
project inject torpedo crazysk8r777 ZipZaps Mods and Projects 6 12-19-2005 03:33 PM
Project Bit-X Pietak440 Bit Char-G Mods and Projects 81 07-14-2005 03:15 AM
My First "Big" Project wasuri Bit Char-G Mods and Projects 2 11-30-2003 05:58 PM
Project Ideas sokalxballa XMODS Mods and Projects 0 11-23-2003 10:21 PM
