Old 12-13-2003, 01:41 AM
fragile_dog fragile_dog is offline
other ppl do have problems, i have 2 3.0's that don't work properly, some times they work fine other times they don't.
Old 12-13-2003, 02:01 AM
R34RKK R34RKK is offline
this sucks!! :(
some motors that work,some that dont,so who do we trust??i dont want to gamble and buy one just to find out its crap!! how do we know?
Old 12-13-2003, 02:11 AM
boho's Avatar
boho boho is offline
Camera springs
Ok folks, slow down a little. How do you check to see if the motor is bad? Simple, connect it to a AA battery. I keep a 3 volt camera battery on hand for this.
Basically: Take the battery, set it on the desk with the positive end up. Place the motor on top. Now find something cunductive that you can connect the back of the battery with the back of the motor, i.e. wire, metal sisors (open them, you'll see). Don't worry, it wont shock you. It's too low of a voltage. Also, if you get it backwards, it will still work.
If the motor still doesn't work then toss it. If it does work then it probably means the pinion gear isn't connecting correctly with the middle gear on the bit. A common problem, especially with clones. You can fidle with motor placement, change pinion gears, or just check the gears to make sure nothing is clogging it.
Also, sometimes I take a small piece of tin foil and place it behind the motor, between the motor and the metal contact. Sometimes this helps. Don't let the tin touch the heat sink or any other metal besides the back of the motor and the metal pad that touches the back of the motor.
Good luck
Old 12-13-2003, 09:27 AM
cheers for the advice boho, but i think ive just got poor motors, they work and when you give them a push they fly but thats the problem you have to give them a push, might be a pinion problem but my 2.6 runs fine :/.
Old 12-13-2003, 02:14 PM
yep same here!!
Old 12-14-2003, 06:40 AM
PauloBecker's Avatar
PauloBecker PauloBecker is offline
Terrible purpose
Send a message via ICQ to PauloBecker
I dunno but that doesn't look like a motor problem to me... If it works when you give it a push, then it's because it has not enough power to take off. You see, PUTTING something into movement takes more energy than KEEPING it moving. I might say that you have either battery or power delivery problems (maybe the wires or something wrong with the PCB?). Again, I'm no expert at this stuff so I might be wrong.
Paulo Becker | [iZaps SE Toyota Trueno:
Police officer: "Have you any idea how FAST you were going back there?"
Werner Heisenberg: "Nope, but I knew EXACTLY where I was!"
Old 12-14-2003, 02:18 PM
viperdout's Avatar
It's Really Fast!
Charge the car up, then take off the rear axle and gear and run it. It might be that some loose hair on the ground that got caught up in it. If it doesn't work, make sure you have the matching color gears, and no clone gears.
Old 12-14-2003, 02:21 PM
hmmmm, the thing is it has no problems working with a 2.6 motor so im just thinking it hasn't got enough toque to start moving :/.
Old 12-17-2003, 03:55 PM
freakanoid
the step by step help plan
[Namuna edit] Good luck with that outwar thing, cause you just got banned for posting bogus links to it.
Old 12-18-2003, 05:53 PM
Originally posted by joecon_ly
newbie here just started getting into these things two weeks back bought superbit rx7 and bitchar-g skyline. recently i got a 3.0 motor from the local hobby shop, and it works fine so d following day i got another 3.0 motor for my friend and like you guys it needs a nudge just to get it going. he tried on diffrent cars and clones as well but same story. Heres the twist, tried on my cars and it worked fine. Strange.
Were from the philippines and the hobby hasnt catched on yet so it hard to get support for this. I personnaly rely on Tiny Rc for anything that i can get.
If someone could figure it out... it would really be great...!\
cheers to you all
hm very interesting...someone should do a test to find this out!!btw i bought mine from ebay...its from some hobby shop in hong kong
Old 12-19-2003, 05:23 PM
viperdout's Avatar
It's Really Fast!
Re: the step by step help plan
Buh Bye! Oh, and BTW, go to this site....
Old 12-20-2003, 01:43 PM
payaso payaso is offline
BIT PIMP
This is a gearing problem that causes the motor to stop.
You need to take the motor out, and spin it just a little bit at a time.
On the back of the motor there is a little tab you can lift it a little bit with a Xacto knife. This is what makes contact with the metal piece in the chassis.
When I say spin it, I mean think of it as a clock. Try different positions with the metal tab on the back of the motor..
Higher RPM motrs are sometimes like this.
Before you put the heatsink back on, hold the motor in place with your finger, and spin the wheels to make sure they spin freely.
silla
