Old 10-22-2004, 10:54 PM
maxximum attack
Originally posted by SHIFT_DRIFT
My Drift chassis.
I made my own "drift wheels" a while back...
Check the mad camber settings on my Z33.
How did you camber thos wheels, why didn't you camber the front ones instead?
Do they wobble or are they really functional? Camber increases grip in turns tho so you may wanto concider doing the front and leaving the rear "stock".
I'd like a tut tho so that I can camber my scooby.
Your wheels are TIGHT!!!
Old 10-23-2004, 09:30 AM
SHIFT_DRIFT's Avatar
5Zigen
They're not loose.
I just added a few bent washers behind the wheels.
The lug nut is on there angled too.
It's just for the "bosozoku"/ drift look.
Try And Sleep Now.
DRIFT my ANTI-rice
Old 10-23-2004, 09:37 AM
5Zigen
Oh yeah, my new drifter... DC5.
I gave in and bought a set of the "drift wheels" and man, they suck.
Well I guess some people like slow drifting with barely no control...
Try And Sleep Now.
DRIFT my ANTI-rice
Old 10-23-2004, 03:55 PM
maxximum attack
They're not loose.
So are the washers wedge shaped?
Can you post a pic of them? _
If you get two wedges and mount them opositely like _// then the nut could still be straight while the rim itself is turned at the angle between the // wedges.
What do you think?
Old 10-24-2004, 10:09 PM
5Zigen
Sound's like it would work.
The washer was juust bent in half at an angle.
It's not really for practical use, just for the nice 'drift" look,
It would be nice to see an actual knuckle camber kit.
The rear camber can be done easily by adding washers to the damper.
Try And Sleep Now.
DRIFT my ANTI-rice
Old 10-25-2004, 04:12 PM
inott40's Avatar
inott40 inott40 is offline
TinyRC Pimp
Send a message via AIM to inott40
my drift machine on beater body
has:
AWD
RS Stage 2 Drift with SB magnets
CF driftshaft
stock rear diff.
6-Cell
Lightend chasis
gangster body kit
Its cheap, and works very well.
too much to list..
inott40's Avatar
TinyRC Pimp
pic 1
too much to list..
Old 10-25-2004, 04:14 PM
inott40's Avatar
TinyRC Pimp
pic 2
too much to list..
Old 10-31-2004, 08:50 PM
djp42588 djp42588 is offline
Send a message via AIM to djp42588
niiiice a very true car i can tell that it is loved
Red Supra = all traction
stg. 2 red motor
suspension, both wheel (im running ones painted white) tire, and body upgrades
speed kills: live long and drive a civic
1967 Camaro = all torque... no traction
md. rear springs and soft fronts side dual exhausts, all go no show and enough power to smoke your civic
Old 10-31-2004, 09:20 PM
stg. 2 red motor
drift techniques turbopimp187 XMODS Mods and Projects 25 07-25-2007 06:40 PM
Drifting explained steelo Miscellaneous Discussion 5 07-14-2007 07:35 AM
Drift Guide 2fast4u XMODS 30 01-20-2007 06:27 PM
Stock ZZ drifting? Elpizo ZipZaps 6 11-06-2006 08:04 PM
