Old 05-01-2003, 07:48 AM
MaddMatt MaddMatt is offline
Send a message via AIM to MaddMatt
how'd you do it?
Killer:
So you took a 1/32 scale tamiya non-r/c truck and converted it to r/c?
Is there anything special to know before I try this as well?
Madd Matt
Matt Walter
Madd Matt's Entertainment
Old 05-01-2003, 08:54 AM
killer's Avatar
killer killer is offline
Proud to be Pinoy :)
Re: how'd you do it?
Originally posted by MaddMatt
Killer:
Madd Matt
:ö:
yes!, that's just it, nothing special ... but i'd like to remind you that the Tamiya 4WD Wild Mini "Monster" Truck stock gear set-up is not built for speed... for crawling, it has more than enough torque to crawl itself up on any trial coarse, but if the need for speed arises, you'll be surprised how fast this truck is when the gear is modified
hehehe
Old 05-01-2003, 10:15 AM
Need for speed
Killer:
Although the need for speed is not why I am pursuing this project, you could also get your truck moving quicker with an upgrade in batteries. If you moved up beyond 300mah you could probably get more speed out of the little monster.
Madd Matt
Matt Walter
Old 05-01-2003, 01:13 PM
binaryterror's Avatar
Fear the 1's and 0's
MaddMatt:
Changing MAH on batteries does not increase power or speed. it will only increase the run time. Voltage will increase speed and power...but the little 130 motors dont really like much more than 6-8 cells. Your best bet is a gearing change if you want more speed.
Old 05-03-2003, 03:19 AM
killer's Avatar
:ö:
Madmatt,
binaryterror is right, increasing Mah does not affect speed of the truck or any rc vehicle, instead, you'll notice a considerably increase in run time.. as to what the MaH stands for; Milli Amps per Hour, so if you want to increase speed, it's either add more cells to your kit, or upgrade your gears and electronics... or use a faster, powerfull motor instead.
hehehe
Old 05-18-2003, 02:27 AM
killer's Avatar
my new truck! though it's just 90% finished
hehehe
Old 05-18-2003, 02:28 AM
killer's Avatar
hehehe
Old 05-18-2003, 02:29 AM
killer's Avatar
side view
hehehe
Old 05-18-2003, 02:30 AM
killer's Avatar
on top of my hand....
hehehe
Old 05-18-2003, 02:31 AM
killer's Avatar
cantilever suspension... though not yet complete..
hehehe
Old 05-18-2003, 02:33 AM
killer's Avatar
top view of test fitting with electronics.
hehehe
Old 05-18-2003, 07:41 AM
slugbugg slugbugg is offline
I KNOW NOTHING!!!
that is looking very good Killer
That has to be one of the best mini monster trucks I have seen yet.
Where did you get the U-joints from? did you make them or buy them somewhere?
I am getting very close to being able to make one also, I'm just getting tooled up for projects like that, actually after my bit project(it's sort of a test project) I will be starting a micro monster truck project 1/43 scale and if that works I will go smaller yet.
Old 05-18-2003, 08:42 AM
killer's Avatar
thanks slugbug! , if you are referring to the u-joint on the steering, i made them out the stock 4mm steel axle of the 1/32 Tamiya Wild Monster Truck..
hehehe
Old 05-18-2003, 08:45 AM
killer's Avatar
but if you are referring to the u-joints on the propeller shaft, i made myself out of allum tubes.. which we are planning to sell in the near future, i'm still testing the durability and strength of those u-joints. ... oh and here's a picture of my 1/87 4x4 chassis which is powered by a 7mm pager motor..
hehehe
Old 05-18-2003, 08:47 AM
killer's Avatar
size comparison of the 1/32 4x4 chassis with my 1/87 4x4 chassis..
hehehe
ZipZaps Monster Truck FAQ Namuna ZipZaps Monster Truck 4 12-20-2010 10:52 AM
Monster Truck! IsToR TTTT Gallery 26 12-18-2008 10:50 PM
xmods monster truck ts185r XMODS Mods and Projects 10 02-20-2006 03:40 PM
Pics of my ZipZaps Monster Patrol Monster Truck -:) rfnagel ZipZaps Monster Truck 20 11-19-2004 07:13 PM
How big are the micro machines monster truck tires? Ovgron Bit Char-G Parts and Hop-Ups 0 06-18-2003 03:09 PM
